Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 09-06-2008, 09:51 AM   #1
Sierrapapa
Sierra Papa
Profile:  2007 25' International CCD
Preston , Idaho
Bent Stabilizer
I have a bent front Stablizer on my 2007 International. It is a BAL. My question concerns the switch out of this bent unit for a new one. If I just undo the bolts, is the frame threaded and the bolts screwed into the frame? I am not much of a mechanic and most things I take apart have been sabatoged by some demon and as I loosen the last fastener nuts and various components fly everywhere and roll into obscure and dark corners, never to be seen again.
So if this is beyond the most simple of projects, I better take my silver darling into a commercial vendor.
Your Counsel??
Sierrapapa is offline   Reply With Quote
Old 09-06-2008, 10:02 AM   #2
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
You can just unscrew it, there should be 3 self tapping bolts into the frame.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 09-06-2008, 10:53 AM   #3
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Ditto on Bob's response. It should work pretty easily with a socket set or even a fixed combination wrench. A crescent wrench would be a pain.
Get a new B.A.L. stabilizer from an Airstream dealer only. If one's not handy to you shipping will be a heavy hit. B.A.L. also makes the same looking stabilizer for SOB trailers but the adjusting rod isn't long enough.
Old 09-06-2008, 11:45 AM   #4
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Early on I have a stabilizer bend from pulling out of a campground forgetting I had put just one down.
If you remove it you can most likely straighten it out and reinstall it. What I did was remove all 4 and weld pieces if 3/4 angle along each of the stringers that support the stabilizer. That is the week point on the stabilizer.
Bad day to take a picture what with a storm coming but I trust you can see the angle on one of the stringers
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 09-06-2008, 02:46 PM   #5
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
The impact which bent the stabilizer may have damaged the hole the screw(s) attach to. If so just use a larger self tapping screw
Like a couple of Balboas we headed into the wild pavement of yonder with a monstous piece of aluminum hooked to our rear end. "The Long, Long Trailer".
Old 09-07-2008, 10:03 PM   #6
Sierrapapa
Sierra Papa
Preston , Idaho
Hey, thanks everyone. I will get that sucker changed, sounds like it is easy enough to maybe fit within my skill set parameters.... now that I have your counsel.
Old 11-19-2008, 09:48 PM   #7
kgdunaway68
Garvin
Profile:  Carthage , Missouri
Where can I get parts to rebuild a front stabilizer with a bent all thread rod?
kgdunaway68 is offline   Reply With Quote
Old 11-21-2008, 06:20 PM   #8
kgdunaway68
Garvin
I'll answer my own question. Ultra Fab 574-294-7571
Old 11-21-2008, 07:20 PM   #9
whitsend
whitsend's Avatar
Profile:  2003 30' Classic
1954 25' Cruiser
Wimberley , The Republic of Texas
Bent Stabilizer
Originally Posted by Sierrapapa View Post
I have a bent front Stablizer on my 2007 International. It is a BAL. If I just undo the bolts, is the frame threaded and the bolts screwed into the frame? So if this is beyond the most simple of projects, I better take my silver darling into a commercial vendor. Your Counsel??
Sierrapapa - Believe me, if I can do it, ANYBODY can. The screws are just self tapping and were factory installed into your frame. Buy a new stabilizer, use your trailer's jack to lift the front of the trailer a little, remove the existing screws & damaged stabilizer, hold the new stabilizer in the same spot, insert the new screws & twist to hand tight. Hold the stabilizer in place and begin tightening the screws. Job completed.
Go get a cold beer.
Whitsend in Central Texas
"I TOLD you an hour ago to stop for some diesel" she said, once again!"
"I TOLD you not to take this country lane at 9:45 at night" she said"
whitsend is offline   Reply With Quote
Old 11-21-2008, 09:57 PM   #10
Distantdrummer
Distantdrummer's Avatar
Profile:
Arrow
Is BAL still the same company it was in the '70s ?
Were BAL stabilizers different for different models within same mod year?
Is there a model number stamped on the stabilizer?
Were BAL stabilizers pretty much unchanged for many years? i.e are the '70 era BALs all the same?
Can we buy parts direct from BAL? Where is BAL anyway?
>>RIGHT HERE>>>> http://www.norcoind.com/bal/products...stabjack.shtml
In Compton California or Elkhart Indiana
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 11-21-2008, 10:07 PM   #11
CanoeStream
Images: 13
You will find BAL stabilizers on their website that look just like what is installed on Airstreams. I've run across these at SOB dealers and for a seemingly fair price. But don't use those sources. The threaded rod needs to be longer for Airstreams so that they can make it out to the curve of the underbelly. You'd want to source them through an Airstream dealer.
Old 11-21-2008, 11:54 PM   #12
Dan4odm
Commercial Vendor
Dan4odm's Avatar
Profile:  Currently Looking...
Colfax , North Carolina
bal
Your Counsel??
It is a pretty easy install, and Airstream has the Long shaft ones made so you won't have to get on the ground to crank them down.
I have never had any luck straightening them out.
Click here to see what the long shaft one looks like.
Dan
We have the best prices on shipping. If we can ship your parts a cheaper way, we do so and pass the savings back to you.
Dan4odm is offline   Reply With Quote
axle bent? air66stream Axles 1 10-05-2007 05:12 AM
bent door kcbrady Doors & Locks 3 11-28-2006 06:04 AM
Bent Wheels jim8860 Mechanics Corner - Engines, Transmission & More... 2 03-08-2006 08:17 PM
third axel bent patrick mckenzie Airstream Motorhome Forums 3 06-23-2003 06:32 AM
Bent (?) Door Jabba Doors & Locks 1 10-26-2002 11:44 PM
