Old 01-06-2008, 07:07 AM   #1
P&J
P&J's Avatar
2008 25' Safari FB SE
Schaumburg , IL
Bearing Level - where to install? which one?
I have a 2008 25" Safari SE FB. I would like to install a level. I puchased this one at Camping World. After I got it home I saw that I would need to SCREW it into the skin of the AS. Do I want to do that? Does anyone have a different level or other suggestion? After reading all the other posts about leaks I don't want to add to my worries.
Judy
P&J is offline   Reply With Quote
Old 01-06-2008, 07:20 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Those levels are mounted to the body, usually centered under the front window.
I have used these on all our Airstreams, and recomend them:Reese Trailer Accessories
They mount on the A-frame, near the tongue jack. No holes in the body required, and they are inexpensive.
Old 01-06-2008, 07:21 AM   #3
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
I use a 1' magnetic level from Sears ($5) on the A-frame at the front of the trailer and it works fine. From what I have been able to tell, when the A-frame at the front is level, the entire trailer is level.
I have been removing the level when I move the trailer but it could be tied down with wire ties for a permanent solution.
SilverCottage is offline   Reply With Quote
Old 01-06-2008, 07:21 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have one of those mounted just below the front window. It was installed by the PO. With a little dab of vulkem you should not have a problem with leaks. If you remove it later you can always put a few Olympic rivets in the holes.
What is nice about this level is not only will it tell you which side is off, but by how much. Last weekend at the Picacho Rally I backed into a spot and then looked at the level. It was three lines off. I moved the trailer forward, built the ramps for 3 levels (3 inches) and backed onto the ramp. The trailer was then level.
The down side to this level is that it is slow. Since it is a steel ball rolling in a liquid it does not react as quickly as an air bubble.
Richard
Old 01-06-2008, 07:24 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Judy
Oh the agony I have a hard enough time drilling into my 37 year old AS. The only place I have seen these, and where I have mine, is below the front window, where it can be seen from the TV. I also tried to figure how to put it on without drilling and went for the holes. There are a couple of other electonic systems out there. Don't know about mounting.
Old 01-06-2008, 07:30 AM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
Set up the level so that the trailer is leveled to the refridgerator. Use a bubble level inside the freezer. Then mount the outside level so that it reads level. This is fairly important with vintage units. I'm not sure if it's a big deal with newer coaches.
Old 01-06-2008, 10:00 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I'd mount it so I could see it from the driver's seat. Just seal the screws well.
Pat
pmclemore is offline   Reply With Quote
Old 01-06-2008, 10:07 AM   #8
2002 25' Safari
Dewey , Arizona
Images: 62
With my previous TV I could see it, but the bed walls in my new TV are too high.
Richard
Old 01-06-2008, 07:22 PM   #9
Ready-to-Travel
pmclemore's Avatar
Yeah - good thing we travel with a second set of eyes, eh?
Old 01-06-2008, 07:59 PM   #10
Images: 59
I think its important to not overtighten the mounting screws. They need to be slightly loose so you can adjust the level as necessary, using the Crowhurst levelling method:
How to get the trailer perfectly level
This seems a good day to describe my recommended method of perfectly levelling the trailer from side to side. I first get the trailer sufficiently level for comfort and for using the refrigerator by using one or two planks under one side. Then, I go to the large bubble level fixed across the front of the trailer, and the bubble will usually be off by an inch or so. The level is mounted with two screws through vertically slotted holes. Here is the important part - the screws are not tightened right up. This enables me to adjust the level until the bubble is exactly in the centre of the level marks. It works every time, and my dear wife and fellow campers are always impressed with the accuracy of this method. Nick.
Originally posted by Nick Crowhurst
Old 01-06-2008, 08:22 PM   #11
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
Our electric jack has a bubble level in the top of it.
To set it, use a bubble level inside the trailer and get the trailer as level as possible, then adjust the bubble level on the jack to match the one used inside.
It works pretty well.
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 01-06-2008, 08:47 PM   #12
CanoeStream's Avatar
St. Cloud , Minnesota
I'm with Denny ... I think. I have one of these:
I glued it on the top of the hitch on the A-frame right in front of the electric jack and breakaway switch. If I have to level I'm in and out of the trailer anyway. It works, it's simple, it's cheap. It's $2.49 at Camping World but I have always found it locally at farm/fleet stores, RV dealerships, etc.
5 meter Langford Nahanni
Old 01-06-2008, 10:52 PM   #13
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, for now I just use a small carpenter's level, about one foot long, on the trailer's frame or on top of my battery box. If and when I plan to install one or two on my trailer, I will most likely use two sided tape. No rivets, no screws, and no holes.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-07-2008, 03:49 AM   #14
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
I just throw a level on the AS floor. Works fine. Have to walk back a couple times, or, have someone watch it as I run jack.
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Level Master Help HHP On The Road... 8 10-17-2006 07:54 AM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
Rivetmaster Level JimGolden Forum Admin, News and Member Account Info 9 10-24-2005 03:07 PM
How level does it need to be? joshua32064 Our Community 10 12-08-2003 07:07 PM
Level Indicator Alex Jacks, Stabilizers, Lifting and Leveling 3 12-03-2003 08:27 AM
