Old 01-07-2008, 07:32 AM   #15
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
return it. One came with my trailer. My dealer refused to install it. He was not going to put holes in my trailer. I use a small torpedo level on the counter top.
Michelle TAC MT-0
Sarah, Snowball
Old 01-07-2008, 07:44 AM   #16
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Go to an auto paint store and get auto trim tape, holds moulding on, use it and the level will stay perfectly till you want to remove it.
jkcru is offline   Reply With Quote
Old 01-07-2008, 10:43 AM   #17
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Echo that above ...... two sided tape. Available at most big box stores. When you want to remove use a hair dryer to heat up the old tape and it will come off.
>>>>>>>>>>>>>Action
Old 01-07-2008, 01:28 PM   #18
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
My dealer uses these levels and has one mounted on every Classic trailer he sells. He mounts them under the front window but markedly towards the street side of the trailer. I can see mine from my drivers side mirror. He does this to allow you to see the level without having to get out of your vehicle. It works as long as you have ample daylight.
At the time I bought my Safari new, he wasn't providing these levels. I mounted my own, first leveling the trailer using a level on the A frame, then double checking with a bubble level inside the freezer compartment. I placed masking tape on the body marking the drill holes and drilled through the aluminum with a very small bit. The key was the masking tape and drilling very slowly to keep the bit from traveling across the aluminum prior to it getting a bite into the metal.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-07-2008, 03:47 PM   #19
Central , Mississippi
Originally Posted by markdoane
I think its important to not overtighten the mounting screws. They need to be slightly loose so you can adjust the level as necessary, using the Crowhurst levelling method:
How to get the trailer perfectly level
This seems a good day to describe my recommended method of perfectly levelling the trailer from side to side. ...
Originally posted by Nick Crowhurst
I'm not sure if something got lost in translation but the best method is the 180 degree method. Stop in a fairly level parking lot and mark exactly where all of the tires are with chalk (on the concrete). Tweek the side to side bubble/ball indicator until the ball is in the middle. Pull the trailer forward and do a 180 degree turn, parking exactly where you were previously (thus the need for the chalk marks). If the ball is not centered move it 1/2 of the distance to the center. It will now be centered when the trailer is level. Now all you need to do is level the trailer and put a bubble inside the fridge to see if it was mounted level in the trailer...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Level Master Help HHP On The Road... 8 10-17-2006 07:54 AM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
Rivetmaster Level JimGolden Forum Admin, News and Member Account Info 9 10-24-2005 03:07 PM
How level does it need to be? joshua32064 Our Community 10 12-08-2003 07:07 PM
Level Indicator Alex Jacks, Stabilizers, Lifting and Leveling 3 12-03-2003 08:27 AM
