Put it on the negative side vs the positive side. Less arching.
>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Jack,
Where is your battery compartment? How far away is your frig vent opening? You might even mount the panel with double sided sticky tape on top of your AC shroud or fabricate a metal mount and run the cable down through the frig vent. I doubt that anyone would climb on top of the trailer to remove your panel because they would not see it.
__________________ Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Craig,
According to my owners guide, my Safari is prewired for solar power. My battery is in a battery box outside the trailer behind the gas bottles. I'll have to ask my dealer what and where the prewire is since I can't fathom the wiring schematics.
Jack
Jack Canavera
STL Mo. AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Jack,
I have visited the www.rvsolarelectric.com site so often and have received their catalog. At some point in time I plan on buying an'82 Excella II 25' model and outfitting it with a 120 watt solar panel package. Until then, I will enjoy my current model and keep the batteries up with the 5 watt model.
I'm not sure where the connections are on your prewired for solar setup. Some have posted that they are hard to get to so they run the wires down the fridge vent and hook up at the junction block there.
AIR #0078
3.73 rear end
Action''s advice to put the disconnect in the negative (ground) lead of the battery is good, but the arcing is going to be the same with it on either lead.
The real reason for this is safety. You should always hook up the positive lead of a battery first and disconnect it last. That way, if you accidentally short to ground in hooking up or in unhooking, there is no arc because there is no circuit.
That was first taught me by an aircraft mechanic (A&E) too many years ago to count.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
I know that the trailer is grounded to the tow vehicle via the hitch and the ground wire in the wiring harness that comes from the tow vehicle.
Is the trailer grounded to the negative side of the trailer battery too? If so I do not know where the ground wire (of the trailer battery) attaches to the trailer. Not that I have looked very hard, however it would be nice to know the location.
>>>>>>>>>Action
Jack,
This is my 5 watt Solargizer solar chanrger/maintainer. I tilted it down to give you a better view but it usually rests on top of one of my propane tanks.
AIR #0078
3.73 rear end
