Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 03-27-2007, 05:26 PM   #15
bake315
bake315's Avatar
Profile:  1994 34' Limited
Elgin , Texas
Images: 161
Originally Posted by SmokelessJoe
Jeez. With 20,000 members here you’d think somebody would know the answer to my original question.
I called Jackson Center. They use BARKER.
Is there any measurable difference between Barker and Ultra Fab??
Airstream didn’t know. Does anyone else?
Sergei
Sergei,
The tenor of your replies to others' posts here smacks a little of arrogance, and is not warranted. I think those who have responded here have tried their best to answer your specific questions regarding "relative merits" and "measurable differences" between Barker and Ultra Fab. All I could do is offer my experiences and opinions regarding one of the two. Most people will likely be in this category, I would imagine. Measurable differences? What are you asking for here - a side-by-side specifications breakdown? Motor voltages of each? Gear ratios? Beyond these types of things, each of these jacks is fundamentally like another, is like another, is like another, and so on. I'm not surprised Airstream didn't have your answer - I doubt they spend that much time thinking about it - they likely use what ever makes the most sense from a unit price perspective. If you really want to see a true comparison between the two, you might be best served by contacting Barker and Ultra Fab directly and ordering a specifications sheet on each model that interests you. Better yet, if you can get one of their design engineers on the phone that might be even better. That way, pound for pound, you can judge for yourself the difference. Essentially berating forum members like you do in your quote for not readily having the answers you require is also not a fair-minded approach to take. If this is something you deem of high importance, that's fine. This is clearly not data that anyone currently has here. Therefore, may I suggest that you go out and discover it elsewhere, and if you so choose, make that information available to the forum. Or not. Obviously that's your decision.
Cheers, Dave
"Finish."
AIR #4188
1994 34' Limited / 2002 Chevy 3500 CC 4x4 D/A Equal-i-zer Hitch / Jordan Ultima 2020
bake315 is offline   Reply With Quote
Old 03-28-2007, 09:33 AM   #16
SmokelessJoe
SmokelessJoe's Avatar
Profile:  1976 Argosy 24
TORONTO and Southwestern , Ontario
Thanks, went with Ultra Fab
Thanks to all for your contributions.
I decided to follow Sugarfoot’s example and went with the Ultra Fab.
Details on my main thread, post #190:
http://www.airforums.com/forum...-18448-14.html
Sergei
SmokelessJoe is offline   Reply With Quote
Old 03-28-2007, 03:30 PM   #17
SmokelessJoe
Footnote
Dave,
Sometimes on these forms when you ask opinions about different brands, anything from toilets to axles, you get many opinions to help sway your decision.
I just thought it might be the same with power jacks.
Sorry if I raised your Texas dander. I meant no harm.
Sergei
Old 06-11-2007, 11:19 PM   #18
mandolindave
mandolindave's Avatar
Profile:
Hey Serg, my electric jack just went kaput.
I was very interested in the same answers that you needed. I would fault no
one for not knowing the answers to your question, but why do people reply when they don't know the answer. If people need more rivets, they could always play one of the many word games. I think Dave was kinda tough on you.
mandolindave is offline   Reply With Quote
Old 06-12-2007, 06:16 AM   #19
flyfisher
flyfisher's Avatar
Profile:  2004 30' Classic
Lancaster County , PA & MT
Sergei -
I have factory installed Ultra Fabs on my 2004 Classic Limited. Perhaps Airstream changed for the 2005 and later model years.
Mine have worked fine -- one of the few things on my trailer that have had no problems so far.
One of the things with Ultra Fabs (perhaps Baker is similar) is they are actually designed to lift your trailer somewhat if needed for leveling purposes (the weight limit varies by model).
Originally, I thought they were just for stabilizing, but when I read the owner's material that came with them, I saw they actually had a lifting capacity. I called Ultra Fab and talked to one of their guys and he explained this to me in some detail - telling me how to use them to lift various corners of my trailer to level it. (I do use them a bit for levelling, but not more than 1" or so since I'm still a bit skeptical of doing that).
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 06-12-2007, 07:58 AM   #20
SmokelessJoe
Thanks for the information, John.
When I get closer to going out on the road I’ll call Marv at Ultra-Fab for a talk through explanation of the leveling capability. Sounds useful.
Sergei
Old 07-02-2008, 12:41 PM   #21
berney
Profile:  ashland , Oregon
I have an ultra fab 3502 that just gave up the ghost...the motor does not work.
The hand crank does work fine. I went to Amazon to read reviews for Ultra Fab and
found that 5 of 6 people had serious problems with their recently purchased
ultra fab. Unfortunately there aren't any reviews for Atwood and Barker jacks
that I have been able to access. A replacement motor for mine is hardly less than
a new jack. I'm thinking I'll go with the Barker.
berney is offline   Reply With Quote
Old 07-02-2008, 01:15 PM   #22
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
For what it's worth regarding motor failure, there is on item you can check if you're adventurous. New style motors use a thin steel case and two strong ferrite magnets for the stator (field) instead of wirewound magnets. The ferrite fields are glued in and can come loose from a plentitude of causes including heat, vibration, impact and moisture. If they come loose they will migrate until they are in proximity instead of diametrically opposed and the motor will cease to function. You can open the motor and inspect it for this problem. If that is the case, the magnets and housing can be carefully cleaned and re-epoxied (180*) from each other) and you'll be back in business. I've done this many times on many devices, mostly windshield wipers and jack motors.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-02-2008, 01:26 PM   #23
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Originally Posted by Silvertwinkie View Post
....... There is one that the factory puts on once in a while that I've seen that has a round level on top of the motor box, and I've heard good things about that one, ......
That's the one I have on my Overlander. It's really good..
Uwe
Old 09-04-2008, 10:13 AM   #24
Zeppelinium
Registered User
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Jack hole diameter
Anybody know what the standard jack hole diameter is on the '70s Airstreams? I'd like to order a jack before the PPL sale is over and I'm away from home for a couple of weeks. Ack!
Zep
Zeppelinium is online now   Reply With Quote
Old 10-09-2008, 09:58 AM   #25
Sugarfoot
Sugarfoot's Avatar
Profile:  1960 24' Tradewind
1956 30' Sovereign of the Road
Southeastern Area , Tennessee
Ultrafab update
FYI for Ultrafab tongue jack users. After 2 years I just had to replace the jack switch. Ultrafab's switch location is a design flaw that lends to the collection of water and eventually shorting out. The manual crank worked fine when the switch died. I still haven't had motor issues or other problems.
Also, Ultrafab no longer makes the manual hand crank. They now have a bit for your cordless drill that does the job if your switch or motor is dead. You can't get it online yet. Call Ultrafab at 1-574-294-7571 and ask for the manual override bit, part number 38-001020. It costs $15 plus shipping.
• • • Aluminocentricity • • •
Sugarfoot is offline   Reply With Quote
Old 10-09-2008, 11:38 AM   #26
craftsman
craftsman's Avatar
Profile:  2007 25' Classic
Hydes , Maryland
Originally Posted by bake315 View Post
Sergei,
I noted a little frustration but I didn't get the impression that any forum members were being berated. A little sensitive maybe?
Craftsman
craftsman is offline   Reply With Quote
Barker H & H Super Jack Problem-HELP!!!! Titu & Gail Jacks, Stabilizers, Lifting and Leveling 3 04-29-2004 08:43 PM
voltage for electric jack maznblu Towing, Tow Vehicles & Hitches 3 04-16-2004 09:32 PM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 07:51 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 11:45 AM
