Old 12-22-2015, 05:57 AM   #1
2008 23' Safari SE
Houston , Texas
Barker Jack blowing fuses
Just got the “new to me” trailer earlier this month. It’s a 2008 Safari SE 23FB. While hitching up the electric jack quit. Batteries were full so checked the fuse. It had blown. Replaced the 30A fuse and it blew again, replaced to no avail, kept blowing fuses. Tried the manual crank and it wouldn’t turn. Why not? The PO was nice enough to meet me at the storage facility and we got it jacked up and off the ball with a bottle jack. Replaced the fuse again and it seems to be working somewhat normally. What happened? Did the jack shaft get in a bind? Since this is the original jack 8 years old, I’m thinking of replacing. I believe it’s a Barker as Colonial said it is what came on the unit. Suggestions?
Rocket53 is online now   Reply With Quote
Old 12-22-2015, 07:04 AM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Does it work now with weight on it?
I'd just replace the jack, preferably with another manufacturer's jack. Just verify the jack head will clear the propane tank cover.
Airstream is no longer using Barker jacks but have switched to Atwood.
Kelvin
Old 12-22-2015, 07:28 AM   #3
2008 23' Safari SE
Houston , Texas
it was working when we left the storage facility. Will run by tomorrow and get all the specs off of it and then head to Camping World.
Old 12-22-2015, 07:49 AM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
possibly a short in the wiring somewhere. Mine was giving me headaches - again - until I pulled the ground wire, cleaned the connection and retightened it. Probably needs some dialectric? grease.
Paula
Old 12-22-2015, 08:13 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If the extension/ retraction range is off when the motor will not shut off when the maximum/minimum extension is reached and blow a fuse. This can be manually reset.
Old 12-22-2015, 08:16 AM   #6
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Don't spend any money on the Jack just yet. Check your batteries. A low voltage condition causes the jack to draw more power. This blows the fuse. That's what happened to us.
Maybe try this: Connect the umbilical to your TV and while the TV is running, try running the jack up and down. If no fuses blow, your batteries may be the issue.
Oh, dang. Never mind, I misread the OP post - you said the batteries were fine and that nothing would move the jack. <sigh>. Best of luck, maybe you need a new jack after all.
Rocinante is our 2014 International Signature 27FB
Old 12-22-2015, 09:34 AM   #7
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
The issue of note though is the OP describing the manual crank override as not functional either. I've replaced my Barker jack toggle switches twice so far; they burn out fairly readily -- even when burned out, and the fuse removed, the manual jack executes fine; so would in my mind be an indication of gears bound or destroyed?
There is an annual maintenance procedure to the jack to verify and add grease to the gearing -- I assume this has been undertaken?
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 12-22-2015, 09:44 AM   #8
1976 Argosy 26
Fair Oaks , California
I had a Barker jack at one point . It would blow the fuse every time if it was not allowed to come to a stop before changing direction of travel . Just a thought .
Argosy Heir is offline   Reply With Quote
Old 12-22-2015, 10:01 AM   #9
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Two observations from personal experience.
1. Use only the correct slow blow 30 amp fuses.
2. Check the connections in the fuse holder. I was blowing fuses and found a bad solder joint in the fuse holder. Fixed the connection and fixed the problem.
Give Barker a call, they have a very responsive CS dept.
MICHAEL
Old 12-22-2015, 10:11 AM   #10
CRH
1995 25' Excella
xxxxx , xxxxxx
If it wouldn't manual crank, the gears were bound up for some reason. The fuses blew when the motor became overloaded. I would disassemble, inspect the gears, and regrease. While the motor is free from the gears, I would hit the switch and make sure the motor was still good.
CRH is online now   Reply With Quote
Old 12-22-2015, 11:44 AM   #11
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
With the power head off and best with the trailer supported with say a jack stand or similar try to run the post up and down manually.
Should go pretty easy full retract, full extend.
Hard to retract or extend?
Bent post is a strong possibility. Or internally kaput.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 12-22-2015, 12:53 PM   #12
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Take a look at the inside wiring. Most likely a wire has come off its connection point. That is what happened with me. An easy fix and make sure the wire is tightly put back on its terminal.
TinCan
graysailor is offline   Reply With Quote
Old 12-22-2015, 03:49 PM   #13
50KIP's Avatar
2009 19' International
Woodinville , Washington
As AWCHIEF said, use only SLOW BLOW 30 Amp fuses. They are hard to find and look just like the other 30 amp fuses. Also, try to stop the jack before it is fully extended or retracted. I would suggest getting a bag cover, unless it is never exposed to the elements.
DonS
"It's like magic, only real"
(Bud Light commercial)
Women and cats can do as they please, while men and dogs should relax and get used to the idea.(R. Heinlein)
50KIP is offline   Reply With Quote
Old 12-22-2015, 03:57 PM   #14
2014 23' FB Flying Cloud
1998 34' Excella 1000
I second CHIEF's suggestion to call Customer Service at Barker. They sent me the toggle switch and the limit switches at an unbeatable price $0.00. If the gears have stripped, you may have to get more invasive but the instructions to replace and reset them are not too difficult to master. Replace it? Only if the problem is not with the head.
Don
donm168 is offline   Reply With Quote
Fuses, what fuses? safariuser Electrical - Systems, Generators, Batteries & Solar 8 04-06-2015 05:52 AM
2009 Int'l, Blowing fuses to jack TXMYTX Jacks, Stabilizers, Lifting and Leveling 1 09-24-2010 05:52 PM
Blowing 30amp Fuses takeachance Generators & Solar Power 2 06-14-2007 12:43 PM
Running Lights blowing fuses neil.ervin Electrical - Systems, Generators, Batteries & Solar 11 04-30-2006 07:37 PM
charging/blowing fuses on the Bambi jonoflewis Electrical - Systems, Generators, Batteries & Solar 7 12-19-2005 06:04 AM
