Old 09-16-2015, 04:57 PM   #1
2013 30' International
Arvada , Colorado
Barker High-Power Jack Blows Fuse While Driving
We just purchased a used 2013 International on the maiden trip we started experiencing a problem with the electric tongue jack. I went to unhitch at the campground and the jack would not go down. I checked the fuse and it was blown. I replaced the fuse and lucubrated the jack and gears and the jack worked great. Next day we hitched up still no problem, with the jack we got to our next stop the jack would not work, the fuse was blown. So I replaced the placed the fuse it worked great. So the next morning I pulled the fuse before pulling out of the campground. Next stop inserted the fuse jack works.
So now my questions are:
1. What is causing a 30amp draw on the line when the jack is fully retracted and the switches don't appear to engaged.
2. Is this a problems with the wiring between my truck and the trailer?
3. Has anyone had a similar problem and if so what action was taken to correct the problem?
WoodguyCO
2013 International
2001 GMC 2500HD
Woodguyco is offline   Reply With Quote
Old 09-16-2015, 05:28 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Are you using a 30 amp "slow blow" fuse? Standard fuses can not handle the possible power surge. Also (I had this happen) check the solder joint on the fuse holder. Mine was defective from the factory. A loose solder connection was causing arcing and blowing fuses. When I contacted Barker they thought it was a defective switch and sent me a replacement. Fortunetly I found the fuse holder problem before changing out the switch.
MICHAEL
Old 09-16-2015, 07:07 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Probably a short circuit in the wiring between the fuse and the switch on the jack. Look closely where the wire passes into the jack and through any other holes and across hard edges.
Brevi tempore!
J. Morgan is online now   Reply With Quote
Old 09-16-2015, 07:09 PM   #4
Arvada , Colorado
I'm fairly certain the fuse is a standard 30 Amp fuse I got a deer in the headlight look when I asked for a slo blow fuse. I will check the fuse connection. Thanks for tip.
Old 09-16-2015, 07:19 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, the flat blade fuses are not slow blow like the in-line glass tube fuses. Check for a pinched wire under your propane cover. I installed a circuit breaker instead of a fuse.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-16-2015, 07:55 PM   #6
AWCHIEF's Avatar
Images: 33
Slow blow fuses are carried by NAPA. They were the only place locally I found them. Also Barker has them.
NAPA
782-1355
MDL-30
S30A
Amazon
http://www.amazon.com/Bussmann-MDL30.../dp/B00139MFXM
MICHAEL
Old 09-16-2015, 08:05 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Could be low battery voltage, they don't last long if they haven't been charged and maintained properly. Check for 12.7 volts fully charged.
Doug and Cheryl
Old 09-16-2015, 08:38 PM   #8
2015 30' FB FC Bunk
Ayer , Massachusetts
Mine blew on the road, wrapped it in tin foil and never looked back. It's still notthat way. I guess I should change it.
Ted S. is offline   Reply With Quote
Old 09-17-2015, 05:42 AM   #9
AWCHIEF's Avatar
Images: 33
Going out on a limb and assuming this is a joke.😂
MICHAEL
Old 09-17-2015, 05:58 AM   #10
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I had a similar problem with another AS we had. Rewired from the battery to the jack and no problem from then on. Also, bought the 30A slow blows from an AS dealer and now carry a couple with the new AS just in case
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 09-17-2015, 06:00 AM   #11
2015 30' FB FC Bunk
No, that's a true story. There is something up with that fuse. Someone in the campground we were at said they loose theirs all the time. We were on the road and I didn't have a moment to deal with it. So we jumped over it and kept going. Then I forgot about it.
Old 09-17-2015, 06:31 AM   #12
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Welcome to the Forums from Arvada
Old 09-17-2015, 12:58 PM   #13
2014 23' FB Flying Cloud
Mill Valley , Left Coast
The fuse is glass as said before. ask for an "MDL" type.
It looks different as there is not just a single element (wire) visible in the tube there is also a cylinder and a spring looking thing. It is a time delay style. Linky thing to follow:
Bussmann by Eaton - MDL-30 - Clip 32VAC Cartridge Glass Dims 0.25x1.25" Sz 3AG 30A Time Lag Cylinder Fuse - Allied Electronics
J.B.
jbxx is offline   Reply With Quote
Old 09-17-2015, 01:27 PM   #14
Granbury , Texas
My grandpaw's house had those old time screw-in fuses. He use to put a penny in the socket and screw the fuse back in if and when one blew. Worked until he made it to the local hardware store for replacements. Scared grandmaw to death.
cabinetmaker is offline   Reply With Quote
inverter to power fridge while driving? duggie Batteries, Univolts, Converters & Inverters 39 01-24-2015 05:28 PM
09 Barker Power Jack failed. Replacements? tmarquis Hitches, Couplers & Balls 3 09-23-2010 09:25 AM
Dometic RM2501 constantly runs the igniter? blows fuse... WineStream Refrigerators 19 08-30-2009 07:09 PM
Barker Power jack 3000 Darrell Root Jacks, Stabilizers, Lifting and Leveling 1 08-11-2007 08:33 PM
28' CCD: Right turn signal blows fuse michaero 2002 - 2005 International 4 11-30-2004 09:09 AM
