Old 09-17-2015, 03:09 PM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by cabinetmaker View Post
My grandpaw's house had those old time screw-in fuses. He use to put a penny in the socket and screw the fuse back in if and when one blew. Worked until he made it to the local hardware store for replacements. Scared grandmaw to death.
I think I remember my Dad doing that a time or two. Many a house has burned down because of doing that. That is why Teds post shocked me so much.
MICHAEL
Old 09-17-2015, 04:01 PM   #16
2015 30' FB FC Bunk
Ayer , Massachusetts
Originally Posted by AWCHIEF View Post
Michael, is this the correct fuse? I will order them...thanks
Ted S. is offline   Reply With Quote
Old 09-17-2015, 04:03 PM   #17
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Possible Source Of Blown Fuse Problem
Water and the Barker Power Jack are problematic.
I'm on the third toggle switch and have, at last, solved the problem (I think;-) ).
If you'll look under the bulls eye level on top of the jack, you'll see it floats. And the space under the level is NOT waterproof.
One of the bayonet connectors on the last toggle switch corroded and simply fell out of its socket. AND this switch was less than a year old.
Solution? Get a cover for your jack and keep the water out.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 09-17-2015, 04:34 PM   #18
AWCHIEF's Avatar
Images: 33
Ted, yes, those will work fine.
MICHAEL
Old 09-17-2015, 04:39 PM   #19
AWCHIEF's Avatar
Images: 33
Solution? Get a cover for your jack and keep the water out.]
This is the spiffy little cover that Barker sent with my jack when they returned it to me,
MICHAEL
Old 09-17-2015, 04:54 PM   #20
2013 30' International
Arvada , Colorado
Barker High-Power Jack Blows Fuse While Driving
Thanks, everyone for the info on the fuse and where to start looking for shorts. I'll check the wiring out this weekend and let you know what I find. It is great to know there are a great group of people to turn to for help when it is needed.
Tom
Woodguyco is offline   Reply With Quote
Old 09-17-2015, 04:57 PM   #21
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Mine blew on the road, wrapped it in tin foil and never looked back. It's still notthat way. I guess I should change it.
Going out on a limb and assuming this is a joke.��
Hi, I have replaced several car dash wire looms because of fuse over-ride. [foil, wire, copper tubing, ETC.]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-17-2015, 07:40 PM   #22
2015 30' FB FC Bunk
Thank you, just ordered. Honesty, I forgot I needed to get fuses, if it weren't for this thread I'd probably go on with the foil until something happened....
Old 09-18-2015, 12:41 AM   #23
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Go to Napa and buy the slo blo's by the box.You'll need them.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 09-19-2015, 10:15 PM   #24
Arvada , Colorado
Quick update, today I checked the wiring from the battery to the fuse holder, then to the motor and found no abrasion on the wire. So I looked very close at the fuse holder. The connections on either end of the fuse holder to the wire were tight but the collar that holds the fuse seemed a little loose so I crimp the collar a little tighter I see if that prevents any fuses being blown. Will need pickup some Slo-blow fuses.
inverter to power fridge while driving? duggie Batteries, Univolts, Converters & Inverters 39 01-24-2015 06:28 PM
09 Barker Power Jack failed. Replacements? tmarquis Hitches, Couplers & Balls 3 09-23-2010 10:25 AM
Dometic RM2501 constantly runs the igniter? blows fuse... WineStream Refrigerators 19 08-30-2009 08:09 PM
Barker Power jack 3000 Darrell Root Jacks, Stabilizers, Lifting and Leveling 1 08-11-2007 09:33 PM
28' CCD: Right turn signal blows fuse michaero 2002 - 2005 International 4 11-30-2004 10:09 AM
