Old 12-10-2012, 12:22 PM   #29
Wise Elder
Jammer's Avatar
2010 30' Classic
I suppose it depends where you camp, but this is largely a problem that no longer exists. Maybe in older campgrounds, or in Mexico or other areas where code enforcement is lax. I've never run into a campground that had a miswired or floating ground. If that's a concern, a 3-light tester tells all.
Old 12-11-2012, 07:42 AM   #30
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by Jammer View Post
I suppose it depends where you camp, but this is largely a problem that no longer exists. Maybe in older campgrounds, or in Mexico or other areas where code enforcement is lax. I've never run into a campground that had a miswired . If that's a concern, a 3-light tester tells all.
The last time I had the problem of a miswired or floating ground outlet was in a COE campground in either Georgia or South Carolina 4 years ago.
