has anyone added a stabilizer jack system?
i saw this on a 5th wheel next to us the other days.it looks well made
they make ones for 5th wheel and travel trailers
Lippert 191025 JT's Strong Arm Travel Trailer Stabilizer Kit
Most of the instability is not because the jacks are not strong enough but that there are not enough of them. What I do is put a hydraulic bottle jack under the axle mounting plate on each side which reduces bounce from the trailer bouncing up and down on the axles that are designed to move.
i received the Happijac 191025 Jack Stabilizer Travel Trailer Scissor Jack today
i should be able to install it by the end of sept/2019
Strong Arm Jack Stabilizer system for travel trailers is a one time, permanent installation that virtually eliminates chassis movement in fifth wheels and travel trailers
Stabilizers telescope into place when the jacks are lowered
Turn of the "T"- handle on each stabilizer locks the system in place for a rock-steady RV
Stabilizers retract with the jacks
JT's Strong Arm Jack Stabilizer system for travel trailers is a one time, permanent installation that virtually eliminates chassis movement in fifth wheels and travel trailers^Stabilizers telescope into place when the jacks are lowered^Turn of the "T"- handle on each stabilizer locks the system in place for a rock-steady RV^Stabilizers retract with the jacks
the front are the easiest.
the lateral ones do NOT fit in the front as the spare tire is in the way
the rear lateral stabilizers are easy to bit in .
the two hardest ones are the rear front to back stabilizer
in the as 22FB, the black tank is very close to where the mount go under the AS.
the curb side was mount just ahead of the black tanks
the road side had to be next to the black tank as the grey dump pipe limited where it could be mounted.
i had to cut odd 1" of tubing to make it fit in the stored/travel position
my wife LOVES it. She tested it washing her face and other shaky tasks. she felt little to no movement
you can get them off amazon
The JT Strong Arm Jack Stabilizer system is for travel trailers and is a one time, permanent installation. It virtually eliminates chassis movement in both 5th wheels and travel trailers
make sure you get the travel trailer version and NOT the 5th wheel version
