Old 11-28-2018, 12:22 PM   #1
2016 23' Flying Cloud
Fanwood , New Jersey
Atwood Trailer Jack Failure
Our 2016FC23D has Atwood trailer jack.
Before the last trip, it failed (didn't work with electrical switch). Fortunately, I had bought manual crank, so we were able to take off.
When I turned the switch on, I heard no sound at all, so I think this is an electrical failure.
Is this something I can repair? Or is it better to have a dealer (ours is Colonial) take care of it?
Atsushi
Atsushi is offline   Reply With Quote
Old 11-28-2018, 12:35 PM   #2
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
You can possibly fix it!
Take the four screws off the grey cover and slide the cover off. Most of the time the wire is loose from one of the connectors. Mine was like that. Just hook it up again!
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
xxx Council Rejected! xxx
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 11-28-2018, 12:45 PM   #3
That doesn't sound so bad! I will definitely take a look at it.
Since it made zero noise and showed no movement when switch is on, I'm suspecting an electrical failure, like loose connection you suggested.
Old 11-28-2018, 01:29 PM   #4
2018 19' Flying Cloud
Coeur d Alene , Idaho
Not to be flippant but did you check the fuse. I didn't see any mention of your having done so,
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 11-28-2018, 01:34 PM   #5
Yes, that's the first thing I checked. Sorry; I should have mentioned it.
Old 11-29-2018, 08:57 AM   #6
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Atsushi
Hi Atsushi,*
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 11-29-2018, 10:17 AM   #7
decatur , GA Georgia
Check the ground and fuse
I had the same problem with my jack. First check the ground. Use a wire to connect a clean un-rusted bolt on the hitch where it connects to your trailer and to the battery ground, you can just hold it (by the casing) or use some type of clip. If the wire sparks or not try the jack. If the jack works you need to get a better ground. What worked for me was to lightly sand both ends of the fuse and fuse casing connections, and/or replace the fuse. Some times the in line fuse housing gets full of water rusting the connectors.
Atsushi[/QUOTE]
Decatur is offline   Reply With Quote
Electric Jack failure - what now? dbradhstream Jacks, Stabilizers, Lifting and Leveling 14 06-16-2017 03:18 PM
Power Jack Failure 2016 Flying Cloud 25 jkhoover2 Jacks, Stabilizers, Lifting and Leveling 24 03-16-2017 06:34 PM
Atwood hot water heater drain plug failure Aggie90 Water Heaters, Filters & Pumps 1 09-22-2016 08:46 PM
Power jack failure help, please FreshAir Jacks, Stabilizers, Lifting and Leveling 17 07-12-2009 09:06 AM
Manual Tongue Jack Failure Sugarfoot Jacks, Stabilizers, Lifting and Leveling 38 11-30-2006 07:09 AM
