Old 07-22-2010, 07:53 AM   #1
1968 20' Globetrotter
Kelowna , British Columbia
Atwood stabilizers
I came across a you-tube video of Atwood stabilizers and they seem much easier to set up than cranking down the Bal units. Would they work on my Globetrotter?
Canlib is offline   Reply With Quote
Old 07-22-2010, 09:03 AM   #2
dznf0g's Avatar
Oswego , Illinois
These are really old design. Had them on my 1972 pop-up. Never seen them on anything heavier. You are relying on straight brute force on the rod for all pressure applied. The screw of the BAL allows for mechanical advantage when applying stabilizing force. I suppose they would work, provided a proper mounting place is used, but I wouldn't count on rock solid stabilizing results.
Stabilizers khadley Jacks, Stabilizers, Lifting and Leveling 1 11-06-2008 05:45 AM
Stabilizers or Scissors...? drag'nwagon Jacks, Stabilizers, Lifting and Leveling 34 07-17-2008 10:37 AM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 06:10 PM
BAL Stabilizers kamadeca Jacks, Stabilizers, Lifting and Leveling 1 11-28-2003 12:32 PM
