Old 05-20-2016, 09:14 AM   #1
Displaced Beach Bum
beachbouy's Avatar
2016 30' International
Texas Airstream Harbor , Texas
Send a message via Skype™ to beachbouy
Atwood Jack occasionally won't work
Fuse good... no light, no operation... this has happened before and an hour later it works. Today again no light no work. Batteries good.
Airstream is 6 months old.
We drag Mitzi a 2016 International Serenity 30 with Goodyear Endurance shoes, with an Equal-i-zer 1000 yanked around with a 2015 GMC Yukon XL SLT 4x4, 5.3L V8 ECOTEC3, 3.92 axle, 6-speed auto WBCCI #6111 AIR #107335
beachbouy is offline   Reply With Quote
Old 05-20-2016, 10:17 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Sounds like a power connection problem. I would look for a corroded connector.
CRH is offline   Reply With Quote
Old 05-20-2016, 10:19 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the light is also not working the first thing I would check is voltage on the line feeding the jack. If none there is a bad connection from the battery. If there is voltage there then check the bolts to the tongue as that is the path to ground.
Stick a straight pin in the wire and check voltage with a meter.
2004 Excursion 4x4
Old 05-20-2016, 11:08 AM   #4
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Not an unusual issue. Ensure all connections are tight and corrosion free. Try using a cover to keep moisture out over the long haul. It can be as simple as an inverted plastic baggy or as upscale as you want.
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 05-20-2016, 12:42 PM   #5
Displaced Beach Bum
beachbouy's Avatar
I keep it covered with a waterproof plastic bag and a vinyl bag to keep the plastic from baking.
Old 05-20-2016, 12:50 PM   #6
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
My Atwood power jack motor failed within the first month, but it was a sudden thing where it worked fine and then completely quit. I only mention it because it sounds like you've looked at most everything else. Make sure you have what you need to operate it manually in case it does fail.
SeaLevel is offline   Reply With Quote
Old 05-20-2016, 12:54 PM   #7
MarkJUrban's Avatar
Richfield , Ohio
I am also having issues with my jack. It has an on/off switch, but it only turns on/off the light. I am able to retract/extract with the switch off.
Then we had a time it wasn't working and I used my sway bar to ground the trailer. It then worked.
It's on my list for repairs
MarkJUrban is offline   Reply With Quote
Old 05-21-2016, 10:19 AM   #8
jackson center , Ohio
I would make sure you have a good ground at the Jack base and coupler. The first area to check since the problem comes and goes.Remove one of the bolts and re-install making sure there is no rust.
Schu is offline   Reply With Quote
Old 05-21-2016, 10:42 AM   #9
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Seems like a problem for the Mother Ship in Jackson Center to correct. By the number of issues with the jack, they need to be contacted and told that they need to deal with as soon as possible, since this is unacceptable. I would be steaming.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 05-21-2016, 10:46 AM   #10
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
If you did not change out the fuse, change it and make sure the inline sleeve contacts are clean with solid connections at both ends. If an inline glass fuse has a loose end cap, it will act like that.
Howard L. is offline   Reply With Quote
Old 05-21-2016, 10:54 AM   #11
Thiatt55's Avatar
2016 30' Flying Cloud
Truckee , California
Jack problems
I have had many of the same problems discussed here. I believe I have now found that it is caused by a loose fuse. The inline fuse right at the jack.
Anytime this happens I squeeze the fuse holder together to make better contact and for some time it has always resolved the issue.
Over the 3 years I have owned my 25 FB FC I have had several issues and I bet 75% of these have been related to fuses.
Lets see I had problems with the range hood, Fantastic fans and, of course, the jack and don't get me started on the refrigerator.
Thiatt55 is offline   Reply With Quote
Old 05-21-2016, 12:26 PM   #12
Anna Maria , Florida
I had the same issue. What I found was that the negative wire connections are fastened to the gear housing, which is aluminium, and they got corroded. Just cleaned them up and reattached them and it is working fine. It has become an annual maintenance chore.
franklyfrank is offline   Reply With Quote
Old 05-21-2016, 01:07 PM   #13
Long Island , New York
Often a problem with the ground wire IMO. Disassemble and make sure metal to metal contact is good.
Old 05-21-2016, 01:45 PM   #14
Displaced Beach Bum
beachbouy's Avatar
Went over to our AS and checked the fuse which is good... no corrosion on connections and i keep it covered with a waterproof/sunlight proof bag. Guess it is time to call the mothership and complain again. The problem being under warranty it is a three hour roundtrip drive and was just there a month ago.
Three weeks ago I contacted Airstream Customer Relations about the recall on the LP regulator... they agreed to ship to local repair shop and I have to pay and get reimbursed... Still has not shipped!
Toilet Closure Sticks "Open" Occasionally ddrinks Plumbing - Systems & Fixtures 6 09-17-2015 11:14 AM
Suburban Heater Blowing Cold Air occasionally Cody Madison Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-20-2014 03:39 PM
Water heater goes out occasionally... steveirving Water Heaters, Filters & Pumps 12 10-24-2013 06:06 AM
elec jack won't work, manual override won't budge? Randjg1 Jacks, Stabilizers, Lifting and Leveling 17 07-04-2009 09:19 AM
New electric jack only works occasionally Zmod Jacks, Stabilizers, Lifting and Leveling 3 06-14-2004 08:09 PM
