07-02-2018, 04:36 PM
Rich and Kat
Alexandria
Alexandria
, Virginia
As long as we’re talking about bottle-jacks ...
Is there any reason to have a bottle jack on the road for a 2-axle trailer? Sears has a 12-ton on sale for a reasonable price and thought it might be nice to have but I don’t want to buy it unless it would serve a purpose.
Thanks much and Happy Independence Day “week”!
Take care,
Rich
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF Save
07-02-2018, 04:48 PM
2007 22' International CCD
Corona
A bottle jack is useful for lifting, moving, supporting MANY things, least of which is changing tires.
One that immediately comes to mind is that if your electric tongue jack fails, a bottle jack can substitute for it while you remove the broken jack (they love to fail in the full down position) and wait for the new one to arrive.
Another is: failed stabilizer jack? Then swap in the bottle jack!
I'm sure there are lots more...
07-02-2018, 05:47 PM
Walnut Creek
You don't absolutely have to have one. However, I do. Have not removed it from the box. Used leveling blocks to raise a tire each time there was a need to change it out. Actually that was likely a better plan to spread the load when we were parked on grass with a flat tire.
Was planning to replace the bottle jack with an aluminum racing floor jack. Harbor Freight puts them on sale from time to time. Looked one over today and found it was more steel than aluminum. Not exactly the plan. So, still looking.
Two approaches - 1) a backup for everything. 2) everything needs to do at least two things.
So, no, but I have one. Pat
Two flats on the same side = you need a jack.
Not able to hook up and tow onto blocks = need a jack
Left the leveling blocks at the last camp site = need a jack
So, buy and carry a bottle jack.
07-02-2018, 06:49 PM
Sag Harbor
, New York
As long as we are talking about bottle jacks, here is a recent thread:
http://www.airforums.com/forums/f457...le-183403.html
An essential tool IMO. How else ya gonna lift/push 5 tons when ya need to, just by pumping with one hand?
07-02-2018, 07:09 PM
1974 Argosy 26
Morrill
, Nebraska
The jack you use in your TV is certainly capable of lifting the tongue of your coach. As with a bottle jack, spacer blocks are used because both types have limited travel.
Sent from my VS500 using Airstream Forums mobile app
07-02-2018, 07:25 PM
Rich and Kat
Alexandria
Alexandria
, Virginia
Thanks guys. I saw the other thread but I interpreted it as a requirement for single-axle trailers vs. double-axle trailers. It makes sense that having one or two would be a good thing. The 12-ton looks like wicked over-kill. So maybe I’ll go with smaller jacks... Thanks again! Rich
Rich
KB2ZMF Save
07-02-2018, 08:09 PM
diesel maniac
Airstream - Other
Tucson
, AZ
I think a small floor jack is more versatile and certainly easier to use, and more stable. If you need a bottle jack, like TJ Twinkie suggested, your TV jack can be used.
Brian
07-02-2018, 10:13 PM
Corona
But, but, overkill is a good thing, right? I do it all the time...[emoji3][emoji3][emoji3]
07-03-2018, 01:54 AM
Sag Harbor
, New York
The pro/con discussions are similar IMO, especially if both tires on one side of a 2-axle trailer go flat at the same time. Unlikely, yes, put being prepared is the name of the game here.
Redundancy is a good thing, and, as rmkrum just said:
Having plenty of 2x lumber "jack pads" on hand is also a good thing. Using construction cedar, these pads can also be used for campfire kindling when split.
Have a great Fourth!
Peter
07-03-2018, 09:26 AM
Iron tepee #35
1993 34' Excella
andalusia
TV jack won’t lift my rig. But I’m pulling a 34’ triple axel. I would purchase the 12 ton. Or at least try your TV jack at home, to be sure that it’s up to the task, before needing it down the road.
07-03-2018, 10:02 AM
2016 27' Flying Cloud
Olympia
I have a Harbor Freight floor jack, which stays in my garage as it is HEAVY and awkward. Last year, my trailer fell off of its jack stand at an RV park, and a neighbor fortunately had a floor jack in his pickup bed, which he used to get the front end of my trailer back to level and on its stand. I then bought a bottle jack, which has been sitting in the rear storage bin of my trailer for a year, anticipating its first use. That occurred last week, at the International Rally, in Salem, OR, when my Husky jack lift failed. I got the trailer back home, using the bottle jack to unhitch and later rehitch in Salem, and found and fixed the problem yesterday: the jack's positive wire had become worn and shorted out. I imagine I could have found another neighbor with a jack, but it was nice to have one stored away, ready to use.
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
07-03-2018, 10:55 AM
2002 30' Classic S/O
Garden Valley
, Idaho
I hate bottle Jack's. When you have a flat, many times the jack is too tall to get under the axle. I much prefer a scissor jack for a single axle or TV. Chevy makes a great scissor jack, and I keep one in my Ford TV. For twin axles, the Trailer Aide is the only way to go and is safer too.
Sent from my SM-G935V using Airstream Forums mobile app
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
07-03-2018, 11:40 AM
2016 25' Flying Cloud
Holly Springs
, Mississippi
Originally Posted by pappy19
This is a very important point. If you'll jack using a frame member close to the wheel, be SURE to estimate how much clearance you'd have between the frame member and the tire rim (not the bottom of an inflated tire).
Many of the big capacity jacks are too tall, even unextended, to fit under the frame member.
Similarly, if using the factory-suggested jack point, be sure you have enough blocking with you to safely position the bottle jack close to the jack point.
A warm-up (practice) at home is a good idea so you already know how to proceed for the time when you're next to the road trying to make all this work.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
07-03-2018, 12:04 PM
Tampa
I had my electric jack extended with the truck attached to aid in putting the WD bars on. Then the jack refused to retract!
I couldn't lower the jack, I couldn't release the coupler, and I couldn't move!
I had to get the truck's dinky crank up jack, put it under the receiver, and take the weight off the tongue jack.
I swore I'd now carry a bottle jack.
The jack in my Tundra might be strong enough, but it better be an emergency. The jack is about 8" and requires all the pieces of the lug wrench to be put together to use as a crank. Never again! Even getting it out of it's storage was torture.
07-03-2018, 01:16 PM
Corona
Yeah, the Toyota screw-type bottle jacks are sturdy, but take assembly and a lot of cranking to use. A lightweight floor jack or a hydraulic jack/ jack-stand combo is what I prefer.
Failing that , my AAA card is at the ready[emoji3]
07-03-2018, 01:23 PM
Tifton
, Georgia
You might check out Harbor Freight. They have bottle jacks in various sizes. If 12 ton is overkill, you could get a 8 or 10 ton.
07-03-2018, 02:37 PM
Still Dreaming
1971 29' Ambassador
Sulphur Springs
On the other hand, a bottle of Jack can solve a lot of little problems!!
07-03-2018, 03:33 PM
Corona
Properly utilized, it can reduce the need to even deal with little problems as well....
