Old 09-15-2007, 05:52 PM   #1
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Question Any Exp Changing Tire with Trailer-Aid Ramp
I've seen many threads on how to jack up an Airstream. Has anyone had any expierence with the Trailer-Aid device that Camping World sells (item #10867) that you drive the good tire up on the ramp and it lifts the flat tire off the ground so you can change it without using a jack on the trailer frame?
2dabeach is offline   Reply With Quote
Old 09-15-2007, 06:31 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It works pretty much as advertised, although I now use either my custom-fabbed bottle jack, or break out my bag of leveling blocks. The blocks can serve the same purpose as the trailer aid.
Old 09-15-2007, 06:32 PM   #3
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Hi 2db!
I just used the Trailer-Aid to change the tire on my 28" Excella. Worked as advertised. U do need to think about the kick-back when pulling off the Trailer-Aid. It has a habit of spitting out, so watch it! Mine was in asphalt.
Happy Trails
Michael
ArtStream is offline   Reply With Quote
Old 09-15-2007, 06:33 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
This only works on two- or three-axle Airstreams. I always carry one of my pair of inexpensive wheel ramps. And a bottle jack if I ever hit a road hazard that flattens two tires on the same side. There's no way I'd pay $66.65 for a Trailer-Aid .... oh wait, that's $59.98 with a President's Club membership...
Camping World is always going to be an expensive option. You don't need the tire shaped indent on top to tell you when you're fully up onto the flat part of the ramp. Check your local farm/fleet store or auto supply store. A pair of tire ramps have some other handy uses too. I actually got mine at Wally-world before I stopped shopping there.
5 meter Langford Nahanni
Old 09-15-2007, 06:38 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have my lynx levelers to build a ramp. I have them to level the trailer, why carry an extra tool?
Richard
Old 09-15-2007, 07:56 PM   #6
westernviews's Avatar
2013 27' Flying Cloud
Livingston , Texas
You can get the Trailer-Aid device for about $39 at horse trailer sites. I recently had two of my tires disintegrate in the California heat wave, that is why it got my attention. But I would not pay $60 for it.
westernviews is offline   Reply With Quote
Old 09-15-2007, 07:59 PM   #7
ScottW's Avatar
Hernando , Mississippi
I have used one for years hauling horse trailers. They work well.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 09-15-2007, 08:03 PM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here it is for 29.95 but the shipping is 14.95. I just bought a second one from this person.
"NEW" TRAILER AID Jack Stand, Flat Tire Ramp, BLACK - (eBay item 290140658293 end time Sep-16-07 07:32:05 PDT)
Old 09-15-2007, 08:12 PM   #9
Darned Marathons. Do you know what cold pressures you were maintaining?
Old 09-15-2007, 09:24 PM   #10
Livingston , Texas
The first tire I lost going over the grapevine on #5 into Los Angeles. I had just stopped at a rest stop and checked the tires for overheating and they were fine. I had checked the pressures to be 65 psi the day before. Had planned on just going short distances while it was so hot, but was impatient to get where I was going.
I have driven around 15,000 miles in the five months that I have had my Airstream. Know it had sat on the hot pavement in the Fontana dealership for many months prior to my getting it. Getting all new tires seemed the right thing to do and will give me peace of mind, for awhile at least.
Old 09-15-2007, 09:35 PM   #11
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I am carrying leveling boards. Since I have a dual axle trailer... I have used them to "jack up" the trailer to replace one of the tires. No point in spending money on something when I already have boards that serve the purpose.
Michelle TAC MT-0
Sarah, Snowball
Old 09-15-2007, 10:43 PM   #12
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I have the leveling blocks but also carry 4 - 2 X 6 X 16 boards for the tongue jack our even raising an axle to change a tire. Loosen the wheel (lug) nuts while the tire is on the ground first then raise the axle. After the fresh tire is on snug up the lugs as best as you can while it is up then torgue them tight when it is on the ground.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 09-20-2007, 07:55 AM   #13
Denis4x4's Avatar
Durango , Colorado
Bought mine years ago for $40. Used several times on car haulers and horse trailers. My time is too valuable to screw around with boards and bottle jacks. Too, there's a safety factor using Trailer-Aid ramp and it's a lot easier to store than a bunch on 2X6's. Worth it in my opinion.
Denis4x4 is offline   Reply With Quote
Old 09-20-2007, 08:21 AM   #14
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Can someone answer a ? about these Trailer Aid ramps...are they solid or hollow?
I would like to cut one shorter than the 24" lg but that would only work if they are solid...
Thanx, Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Trailer Tire Rotation moosetags Tires 11 05-02-2015 09:10 AM
double axle repair ramp? pinkflamingoes Axles 30 05-06-2009 02:43 AM
Trailer Tire Mileage moosetags Tires 6 12-24-2006 08:53 AM
Trailer-Aid for changing flats mtpalms Tires 9 06-09-2005 03:37 PM
Trailer tire article 83Excella Tires 0 06-10-2002 09:20 PM
