Old 09-20-2007, 09:13 AM   #15
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Bill, they are hollow with cross bars of plastic supports.
Old 09-20-2007, 09:46 AM   #16
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Thanx Gary, if I cut one down to about 16" long (so it is only the angled/ramp end) would it still be sturdy enough to drive the trailer on?
Here is my intention; I use (2) 4 x 4's 16" lg, cut at about 15deg to level my AS. Just place them under the low side and drive up the angle as much as you need to level. Chock wheels...all done! No boards to mess with. Very easy, infinitely adjustable (up to 4" max ht).
Problem is I, the widest wood I have been able to find, and fit through my saw, is a 4x4. This does not fully support the width of the tire and could lead to damage of the tire bands if left for too long. I have been trying to find something wider.
Years ago, there were some short ramps made of aluminum for this purpose. I saw pix somewhere on this site (don't know if they were made by/sold by AS). But that is where I got the idea. It works great, very easy, beats the heck out of boards.
Thanx, Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 09-20-2007, 07:15 PM   #17
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Bill,
Measured the Trailer Aid - it's only 5 1/4 inches wide so not sure it would work for you. Maybe something like these would work better? They are 7.88 inches wide.
Old 09-20-2007, 10:01 PM   #18
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Originally Posted by 2dabeach
I've seen many threads on how to jack up an Airstream. Has anyone had any expierence with the Trailer-Aid device that Camping World sells (item #10867) that you drive the good tire up on the ramp and it lifts the flat tire off the ground so you can change it without using a jack on the trailer frame?
Check this one. Jiffy Jack - Horse.com
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 09-21-2007, 05:45 AM   #19
1 Rivet Short
1989 25' Excella
Thanx...those both look good.
Gary, do you have a link to that Tr-Leveler?
Bill
Old 09-21-2007, 05:45 AM   #20
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Just thought I'd post a pic from my archives...Have worked on my trailer at a rally using this method. Just be sure you are hooked up and wheels choked on other side. I don't leave home without my boards.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 09-21-2007, 05:54 AM   #21
1 Rivet Short
1989 25' Excella
Yeah, that is what I try to avoid...carrying 1/2 a lumber yard with me!
Pretty sure you should have both axles supported too.
I understand you can overload if you just jack one axle for too long. OK for tire changing maybe, but I would not want to stay like that.
The ramp idea works great-infinitely adjustable-not just in 1 inch increments, I just need to find something wider.
Bill
Old 09-21-2007, 06:36 AM   #22
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here you go Bill - there are also the Lynx levelers - a lot of folks here seem to like those also.
rv levelers, Parts Accessories, eBay Motors items on eBay.com=
Old 09-21-2007, 06:47 AM   #23
1 Rivet Short
1989 25' Excella
Yeah, the Lynx tend to crack if used on hard surfaces. I am refining my ramp idea...works well.
Sometimes the original is the best, this method goes back a long ways, wish I could find a set of those old aluminum ones!
Bill
Old 09-21-2007, 07:01 AM   #24
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Your not thinking of the aluminum wheel risers the trucks use are you? Better have a fat wallet for those......
Old 09-21-2007, 07:26 AM   #25
1 Rivet Short
1989 25' Excella
Nope. There are some old AS ones floating around. I have seen pix somewhere on this site, that's where I got the idea to replicate them put of wood. They work great.
I firmly believe in the K-I-S-S principle and these strongly adhere...brilliant, simple.
(probably would need fat wallet for the AS ones too...if you could find them).
I'll look for the pic, and take a shot of mine this weekend up in NH...
Found it; http://www.airforums.com/forums/f238...-up-25931.html
Bill
Old 09-21-2007, 08:38 AM   #26
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Good luck finding the original one - would be nice, Here's one that might work well without breaking the bank.
Old 09-21-2007, 09:17 AM   #27
1 Rivet Short
1989 25' Excella
Thanx Ganglin...too long to fit between wheels...
Bill
Old 09-21-2007, 10:04 AM   #28
Old Member
Surman1322's Avatar
2000 31' Excella
No-slip Tire Ramp
I have used a ramp to remove flat tires for many years on two and three axle Airstreams. To keep it from sliding on smooth pavement, I put a rubber mat under it. I have also reduced the need for it by going to Maxxis load range E tires on my current 31' trailer.
Surman1322 is offline   Reply With Quote
Trailer Tire Rotation moosetags Tires 11 05-02-2015 09:10 AM
double axle repair ramp? pinkflamingoes Axles 30 05-06-2009 02:43 AM
Trailer Tire Mileage moosetags Tires 6 12-24-2006 08:53 AM
Trailer-Aid for changing flats mtpalms Tires 9 06-09-2005 03:37 PM
Trailer tire article 83Excella Tires 0 06-10-2002 09:20 PM
