Old 04-16-2015, 12:14 PM   #15
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Originally Posted by lsbrodsky View Post
No, I am not going to search for that I only know that I did not purchase because of a thread on here somewhere.
Larry
Sounds legit right there.
Oddly enough, in debate we call this the Burden of Proof fallacy: https://yourlogicalfallacyis.com/burden-of-proof
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-16-2015, 12:24 PM   #16
Tincampers's Avatar
Sneedville , Tennessee
Here ya go. Found it in just a few lines from the top of a Google search:
http://www.airforums.com/forums/f42/...ml#post1473613
Tincampers is offline   Reply With Quote
Old 04-16-2015, 12:37 PM   #17
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I'm one who couldn't use them due to clearance between the wheels. I sent them back. I was on uneven soft ground and that probably had something to do with it. As I recall I could barely fit them in on hard, level ground. But who needs levelers on level ground.
2012 Dodge Durango Hemi/AWD
Old 04-16-2015, 12:38 PM   #18
daveswenson's Avatar
2012 28' International
Issaquah , Washington
So what do you use to determine level, so that you know when to stop?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 04-16-2015, 12:48 PM   #19
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
The level on the front of the trailer, same as any other leveling device. I watch the level and signal my husband when to stop the tow vehicle.
Stephanie
Old 04-16-2015, 02:33 PM   #20
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use a level on the floor.
Name:   ImageUploadedByAirstream Forums1429216419.324847.jpg
MICHAEL
Old 04-16-2015, 02:58 PM   #21
2016 30' Classic
Erie , Colorado
If clearance is tight the Andersen website says you can shave 4 inches off of the small end. With twin axles that would only be needed on one of the two that was fitting into the space between the tires.
For leveling on my FC25 I had a small commercial piece of high strength Velro, small 1 inch square, on the bottom of the front window. When I got to the camping spot I would attach one of these to the window. Picked out the low side, positioned the Andersens, and then would pull ahead until I got the green light, watching in the rear view mirror. Set the parking brake, go chock the tires and then disconnect.
Name:   Screen Shot 2015-04-16 at 2.52.11 PM.png
I've been testing an iPhone app from Harry Schlangmann, Harry's Heavy Duty Camper Edition. With a small device from TI, mounted in the trailer, you can do the balance act with an iPhone, iPad or for those real technoids coming soon on the Apple Watch. TI device is very inexpensive.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 04-16-2015, 04:30 PM   #22
Nomadic , USA
I wonder if the axles are closer together on the 25fter. Here are mine.
ID:	236434   Click image for larger version
Old 04-16-2015, 04:46 PM   #23
2016 30' Classic
Erie , Colorado
I was going to get another set of Roto-Choks and had measured the gap on the 2015 Classic. Measures 3.5 inches. Picking up the trailer next week and will see whether I need to trim one of them down. Looking forward to having to make that decision They worked fine on a 25 with 15 inch tires.
Gary
2015 Classic
ProPride
NVPN
Old 04-16-2015, 05:43 PM   #24
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
OP: yes and I love them!
Bold - are you actually putting the chock wedge under the wedge itself? I would imagine that would be very slippery and unstable.
I understood the chock to go on the opposite side of the tire from the wedge like this:
Name:	ImageUploadedByAirstream Forums1429227732.793983.jpg
Old 04-16-2015, 05:47 PM   #25
2016 30' Classic
Erie , Colorado
I put the wedge under the front lip as you have them Steve. In Bolds photos looks like the tires are still on the pavement and just blocking to keep it from rolling.
Gary
2015 Classic
ProPride
NVPN
Old 04-16-2015, 05:53 PM   #26
W , New England
I'll be ok 😜
Old 04-16-2015, 11:52 PM   #27
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
I wonder, is it better to push back onto or pull forward and on.
Hmm, might cause a heated debate.
Steve, I wish I had thought about those 16s . Anyway no problem with the
2015 27 FB.
DoublTrouble is offline   Reply With Quote
Old 04-17-2015, 04:30 AM   #28
W , New England
Those are 15s (the p rated Michelins).
You can use the Andersens backward or forward - sideways is a real challenge :-)
Andersen-3604 Camper Leveler time2play On The Road... 30 07-20-2014 04:30 AM
Update on rear leveler on my '88 345, has anyone ever replaced an actuator? Mr. D Mechanics Corner - Engines, Transmission & More... 2 05-03-2012 04:35 PM
Anyone use Ramble RV Leveler ramps? barrettjl Jacks, Stabilizers, Lifting and Leveling 3 04-10-2012 06:41 AM
has anyone tried to finance and Old A/S lately? volvophile Financing 16 11-20-2005 11:17 AM
anyone broken down and tried airmark tools Ed Starman Cleaning, Stripping & Polishing 50 04-25-2005 12:57 PM
