04-16-2015, 08:44 AM
Biloxi
, Mississippi
There are several current threads on these. So yes I would say people have used them including myself. Much better and easier to use than the blocks in my qualified opinion.
MICHAEL
04-16-2015, 08:53 AM
2015 25' Flying Cloud
Bend
, Oregon
Yep. I have them. Work well for me
04-16-2015, 09:06 AM
Common Sense
I use them also, and like them. The only issue I have sometimes is getting enough traction to pull the heavy 34' SO up on the wedges, but I would have the same problem no matter what system I used for leveling.
Regards,
Steve
04-16-2015, 10:12 AM
2017 25' International
Carlsbad
I have them also, while I have only used them once, they worked well for me. I am carrying two sets of those lego type of leveler blocks that the dealer gave me but hope to discard those quickly.
Regards,
Jeffrey
04-16-2015, 10:22 AM
2012 25' FB International
Trent Woods
, North Carolina
I looked at using them but, thanks to the forum, I was cautious since I upgraded to 16" wheels and Michelin tires. Others have encountered clearance problems with the bigger wheels so I did not purchase them.
Larry
04-16-2015, 10:24 AM
Common Sense
Larry
Odd, I have 16' wheels/tires on my 34', and no problems at all.
Regards,
Steve
04-16-2015, 10:47 AM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Larry
I have ZERO clearance issues with mine. I'll take photos and post them later tonight. There is a ton of room on my 27ft 2007 International Signature with 16inch wheels and Michelin tires.
Product works as advertised, and is easy to use. Works on concert too, as I'm using them in my storage unit.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
04-16-2015, 10:52 AM
2007 16' International CCD
Somewhere
Have used them on double axle and single axle trailers, and we LOVE them. If there is a clearance issue it would only be on double axle trailers, and one leveler can be trimmed back for use between the wheels.
04-16-2015, 11:20 AM
2005 28' International CCD
San Jose via Winnepeg, Toronto, Orlando, Saratoga and Groton
Those are slick! A game changer, and even look like they take less space than the lego blocks.
2005 28' CCD International
2x120W Solar Panels/22A GoPower Controller
1200# Equalizer Hitch
2007 GMC Yukon XL SLT
"Where are my keys?"
1968 17' Caravel
Battle Ground
We have one and only got to use it a couple times last season. I'm holding onto my BAL Single Wheel Lifter until I'm convinced about the Camper Leveler. I had some trouble with it sinking into soft ground, while the BAL Lifter has a wider base so doesn't sink in. But it's a lot nicer to carry the little Camper Leveler!
Stephanie
04-16-2015, 11:33 AM
1987 Avion 34W owner
Good Ol'
, USA
I would be curious to see how they would work on our Avion 34W (3-axle). I like the Ultimate Duffel Bag set. I guess I'd need to order an extra leveler and chock?
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
04-16-2015, 11:41 AM
Biloxi
, Mississippi
Larry
Can you post links to 16 inchers with issues. I do not recall seeing any of those post.
MICHAEL
04-16-2015, 12:03 PM
Trent Woods
, North Carolina
No, I am not going to search for that I only know that I did not purchase because of a thread on here somewhere.
Larry
04-16-2015, 12:14 PM
Nomadic
, USA
Larry
Sounds legit right there.
Oddly enough, in debate we call this the Burden of Proof fallacy: https://yourlogicalfallacyis.com/burden-of-proof
04-16-2015, 12:37 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I'm one who couldn't use them due to clearance between the wheels. I sent them back. I was on uneven soft ground and that probably had something to do with it. As I recall I could barely fit them in on hard, level ground. But who needs levelers on level ground.
2019 Ford Expedition Platinum
04-16-2015, 12:38 PM
2012 28' International
Olympia
So what do you use to determine level, so that you know when to stop?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
04-16-2015, 12:48 PM
1968 17' Caravel
Battle Ground
The level on the front of the trailer, same as any other leveling device. I watch the level and signal my husband when to stop the tow vehicle.
Stephanie
04-16-2015, 02:33 PM
Biloxi
, Mississippi
I use a level on the floor.
MICHAEL
