Old 04-07-2011, 02:24 PM   #1
2004 25' International CCD
Brookfield , Wisconsin
Aistream 2004 Intl CCD Electric jack problem
Tong jack is not operating with battery or with unit connected to land line. It operated previously with another tow vehicle, but not with my towing vehicle. So there maybe several issues. My towing vehicle plug may not work correctly yet when plugged in the lights on Airstream do light up.
Any pointers for the electric jack?
I would appreciate it.
Dany
danyfr67 is offline   Reply With Quote
Old 04-07-2011, 02:58 PM   #2
2010 27' FB International
La Crescent , Minnesota
On our previous trailer, a 22' 2004 the tounge jack failed. The problem was the grounding. I removed the bolts holding the jack to the frame wirebrushed around the bolt holes and reinstalled stainless bolts.
Make sure the jack is free of any load!!!!
I removed and reinstalled one bolt at a time. I hope this will solve your problem.
Jay
mjayjensen is offline   Reply With Quote
Old 04-07-2011, 02:58 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
There's a fuse in the line somewhere.
Old 04-07-2011, 04:00 PM   #4
Aistream Jack problem
I checked the fuse already look O.K, I'll check the ground.
Old 04-07-2011, 04:34 PM   #5
reddogfox's Avatar
2008 20' Safari SE
Thumb Area , Michigan
If it turns out to be a bad ground in addition to following mjayjensen's advise might try adding star lock washer between the jack mounting flange and the trailer frame before re tightening the three mounting bolts. This technique worked for me.
Richard from MI
20' 2008 Safari SE, Dill TPMS Silver Dog House
2007 GMC 1/2 ton Sierra ARE Cap
AIR # 10494
reddogfox is offline   Reply With Quote
Old 04-08-2011, 05:56 AM   #6
Airstream Jack
O.K that worked, but now I am blowing the fuse when operating the jack, I'll will lubricate the pin and the gear box to see if that does the trick
Old 04-08-2011, 06:04 AM   #7
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
Have you checked the fuse in the TV? We had a problem with our trailer brakes. We have the electric/hydraulic disc variety that require a power feed. In the Ford F250 there is a 20A fuse (in the fuse panel in the dash) for the power feed in the trailer connector. Since it was out the brakes were feeding off the trailer batteries and over time they went dead. Since we had the TV fuse replaced, we've had no problems.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
au_ee is offline   Reply With Quote
Old 04-08-2011, 07:03 AM   #8
dznf0g's Avatar
Oswego , Illinois
You might crank it up all the way, by hand if you have to, and lubricate the post shaft too. Mine had gotten some corrosion over the years and was dragging and laboring badly. Greased it up and it operated much more smoothly and at a higher speed. Excessive drag can cause higher amp loads and blown fuses.
Old 04-08-2011, 08:33 PM   #9
fixed. Had bad ground. Thank you all.
1Owner Clean Airstream International CCD 25ft Front Bed eBay Watch Airstreams on eBay 0 03-29-2011 05:50 PM
2002 Airstream International 22' CCD Designer Edition eBay Watch Airstreams on eBay 0 03-14-2011 06:50 AM
2004 Airstream International CCD 16' Bambi eBay Watch Airstreams on eBay 0 03-06-2011 05:00 PM
2009 Airstream 16 BAMBI INTERNATIONAL CCD eBay Watch Airstreams on eBay 0 02-04-2011 02:30 PM
2009 Airstream 16 BAMBI INTERNATIONAL CCD eBay Watch Airstreams on eBay 0 01-06-2011 08:50 AM
