Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 07-22-2009, 03:27 PM   #1
wiegand01's Avatar
Profile:  1964 22' Safari
Granite City , Illinois
Adding stabilizers to a trailer
I have a '64 22' Safari and was wondering if there was a way to attach those types of stabilizers to my trailer. The old school aluminum ones I use are a pain in the butt.
Nick
wiegand01 is offline   Reply With Quote
Old 07-22-2009, 03:38 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Nick's got a question still open. In the meanwhile...
Nick, if you go this way be sure to get the BAL stabilizers custom built for Airstreams. They're heavy and shipping would be high, so maybe check an Airstream dealer closer to you. I've been to the BAL website and you'll see the same stabilizer but their shafts aren't long enough. It's a long way back to the first longitudinal frame member where they screw in. Therefore Airstreams need a custom model.
Who has put these on an early '60s Airstream?
Old 07-22-2009, 08:57 PM   #3
Profile:  1963 26' Overlander
I know for a fact that Terry (Overlander63) has installed these on a 63 Overlander, because I now own that trailer. He did a great job and they worked well. I have taken them off while replacing the floor and bellypan, but I will reinstall as soon as I'm done with all that.
I also need another two of them for the front. InlandRV carries the ones that are especially for Airstreams, and likely other vendors do as well, but brand new, they are pretty pricey, so I won't be purchasing these for a bit.
Stabilizers khadley Jacks, Stabilizers, Lifting and Leveling 1 11-06-2008 06:45 AM
Stabilizers or Scissors...? drag'nwagon Jacks, Stabilizers, Lifting and Leveling 34 07-17-2008 11:37 AM
Power Twin Stabilizers and fore/aft trailer movement on campsite with slight grade TX_Streamer Jacks, Stabilizers, Lifting and Leveling 7 10-24-2007 11:00 AM
Retrofit electric stabilizers (eg Power Twin II) on vintage trailer? Jacob D. Repairing/Replacing Floor &/or Frame 10 07-04-2007 01:18 AM
