Old 02-22-2010, 07:40 PM   #1
2005 28' International CCD
Diamond Bar , California
28' International jack placement
I need to replace my tires, I found the arrow indicating the jack location. My question is do I place the jack on the arrow or set it in further to line up with the main frame... Thanks
BCMC27 is offline   Reply With Quote
Old 02-22-2010, 09:06 PM   #2
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
There should be a 2"x2" square of aluminum behind the axles on the frame on each side. That's where the service center at JC put the jack on mine.
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 02-22-2010, 10:22 PM   #3
That arrow is "NOT" for jack purposes.
But it is for a stabilizer jack.
Jacking the trailer up should only be done behind the rear wheel, placing the jack on the vertical "axle mounting plate".
Old 02-23-2010, 11:13 AM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Andy, the arrow points to a diamond-shaped piece of aluminum that my manual states is the proper jacking point. My stabilizing jacks (the electric screw kind) are located fore and (further) aft.
Pat
pmclemore is offline   Reply With Quote
Old 02-23-2010, 01:55 PM   #5
Pat
Pat.
What your book says is WRONG.
The book should say "STABILIZER JACK" only.
If you lift from that plate you stand the chance of having the jack slip, punching a hole in the underbelly and maybe in the floor.
Again, that label is for a stabilizer jack, not a lifting jack.
The owners manuals have said that same "WRONG" thing for years.
Old 02-23-2010, 04:05 PM   #6
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
Jack Placement for Tire Change
andy -
- just to pull this thread a little further -
what is the best/safest way for a tire dealer to replace the tires on an AS. i have a 2005, 2 axle 22'.
i plan to replace the 4 tires soon but don't want to take the chance of someone doing damage to my AS.
should they use a jack? a tire ramp? does the AS stay hooked up to the TV while they change the tires?
can i trust what i see in the owners manual?
i would probably want to stay and 'monitor' them while the work is done.
any info greatly appreciated,
az-streamer
[ jon ]
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Donít Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
Old 02-23-2010, 04:48 PM   #7
Originally Posted by az-streamer View Post
andy -
az-streamer
[ jon ]
Jon.
The safest way to lift any Airstream from the 1961 models and up, is to use the axle mounting plate.
For a single axle, place the jack rearward of the tire.
For a tandem axle, place the jack between the tires.
For a tri-axle, place the jack between the last 2 tires.
A bottle jack or a small floor jack can be used.
DO NOT use the spot Airstream has marked to lift the trailer.
That spot marked "JACK" is for stabilizer jacks, "ONLY".
You can lift the trailer with the tow vehicle still attached, but it's not a very good idea, since unusual stresses will be applied to the hitch bars, and the hitch platform.
Old 02-23-2010, 05:12 PM   #8
Images: 20
Tire Stems
thanks andy,
that helps a lot.
this is my 1st AS and will be the first tire change.
i just want to make sure its done right.
in a similar vein -
do you recommend metal tire stems?
i plan to get a remote tire air pressure monitoring system [hawkshead or similar] and i have seen some posts that recommend getting the metal stems as they are more durable.
any ideas/suggestions?
thanks again,
az-streamer
[jon]
az-streamer
Jon & Deb
FCU WBCCI #1601
Old 02-23-2010, 05:50 PM   #9
thanks andy,
that helps a lot.
in a similar vein -
thanks again,
az-streamer
[jon]
Metal valve stems are superior to the rubber type, any day, hands down.
Old 02-23-2010, 08:31 PM   #10
_
unless the diamond is NOT properly located, it IS under the main frame rail, so USE it.
...the arrow points to a diamond-shaped piece of aluminum that my manual states is the proper jacking point....
YES that's the jacking UP location right under the frame rail.
...can i trust what i see in the owners manual?...
in THIS case U can trust the owners manual.
the spot marked JACK is for a tire jack, not stabilizers.
IF you doubt this email the factory and ask.
they use that DIAMOND shaped spot marked JACK every day to lift them.
i've posted pictures of the factory service center USING the marked spot on my 34...
see post #42 below...
http://www.airforums.com/forums/f457...tml#post428907
they do the SAME on the tiny trailers...
ONCE the trailer is OFF the ground via the tongue jack and a jack on the DIAMOND...
jack STANDS are placed under the axle mounting plate for safety while working...
but the DO NOT jack'em up there.
help fight the posting of NONsense, where ever possible...
cheers
2air'
Old 02-23-2010, 09:27 PM   #11
_
...i plan to get a remote tire air pressure monitoring system [hawkshead or similar] and i have seen some posts that recommend getting the metal stems as they are more durable...
FULL metal (outer) stems are STIFFER and are recommended by all of the tpms makers...
because the mass/weight of the sensor can stress/bend stems.
hawkshead will INCLUDE metal stems with the kit and they are OK stems to use.
be SURE that any metal stems are mounted with RUBBER gaskets inside and OUTSIDE...
because any place the chromed steel stem contacts the alloy rims WILL corrode and then LEAK air.
of course IF the wheels are steel AND the stems steel, that's not an issue, but the bambi has alum/alloy rims.
cheers
2air'
Old 02-24-2010, 10:05 AM   #12
BDandTTs's Avatar
2005 22' International CCD
Huntington , Vermont
Images: 49
Jacking 22' CCD
andy -
az-streamer
[ jon ]
AZ-Streamer,
We also have a 22' CCD and recently had to have a tire shop remove the roadside front tire to replace a valve stem. In the first photo you can see that access to the Airstream specified jacking point on the roadside behind the rear wheel is blocked, especially if using a large floor jack. There is maximum of 8.5" between the black and gray tanks that are mounted below the frame, and the waste plumbing is also mounted right next to the frame.
In the second photo you can see where he placed the jack -- I assume this is the vertical axle mounting plate that Andy referred to. (The galvanized tank in the photo is our fresh water, mounted fore of the wheels.)
Hope we did OK.
Dianne of
ID:	96890   Click image for larger version
Bob, Dianne, and Tess the WFT
BDandTTs
Bandit #14576 (WDCU/AIR)
http://www.RWChatelain-Woodturner.com
BDandTTs is offline   Reply With Quote
Old 02-24-2010, 11:49 AM   #13
Images: 20
Jack Your AS [can i say that?]
thanks to: Andy [Inland RV]
2airishuman
BDandTTs
for your great input.
the last thing i want to hear as someone changes my tires is: oops
or: should that look like THAT?
i'm now off in a search for a tire store that knows what an AS is!
again - thank you all for your help and suggestions.
az-streamer
[jon]
az-streamer
Jon & Deb
FCU WBCCI #1601
Old 02-24-2010, 12:21 PM   #14
Originally Posted by BDandTTs View Post
AZ-Streamer,
Hope we did OK.
Dianne of
Dianne.
That jack is placed on the axle mounting "bracket".
The axle mounting plate, is what the axle bracket is bolted to.
Jacking on the axle mounting "plate" is the recommended method.
Airstream International Signature 28' vs. International Ocean Breeze 28' BlueDiamond 2006 - 2010 International 6 04-16-2013 04:25 PM
Jack Stand Use/Placement (long-term parking) binkers Winterizing, Storage, Carports & Covers 12 12-21-2008 07:53 AM
Jack Stand placement, '73 International floridartist Repairing/Replacing Floor &/or Frame 8 10-26-2008 10:38 AM
Jack placement Chitown AirStreamers On The Road... 10 10-07-2003 08:56 AM
placement of jack eikel1we Jacks, Stabilizers, Lifting and Leveling 5 10-04-2003 12:14 PM
