Old 06-11-2018, 08:35 PM   #1
1962 19' Globetrotter
2001 31' Excella
Working with Parbond?
Iíve been experimenting with techniques to apply parbond, but not successfully. For those using Parbond, how do you apply from the tube to get a nice smooth finish?
Craig is offline   Reply With Quote
Old 06-11-2018, 08:54 PM   #2
1966 22' Safari
Fredericksburg , Texas
I use it often. I poke a small pin hole in the tip and use it mostly that way. Colin Hyde said that until you get good at free handing the tube, you should tape off the seams to keep the Parbond in bounds. Good luck, Bubba
Bubba L is offline   Reply With Quote
Old 06-11-2018, 08:56 PM   #3
NHdigger's Avatar
2008 25' Safari FB SE
Milford , New Hampshire
I recently used Parbond for the first time and found it near impossible to draw out a long smooth bead of consistent size.
Ended up going about 1/2-1" at a time, pausing, slight push back on the bead placed and then continuing. Looks bumpy at first but the material self levels to an acceptable look.
NHdigger is offline   Reply With Quote
Old 06-11-2018, 09:04 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I run a small bead, then immediately take a cloth wet with mineral spirits and use my fingertip to press it into the seam while wiping off the excess.
CRH is offline   Reply With Quote
Old 06-24-2018, 06:15 PM   #5
1981 31' Excella II
New Market , Alabama
I have found that if you move the metal tip forwards and backwards along the seam, it makes a smooth fillet without having to resort to solvents etc. 3 steps forward, two steps back.
Perry
Caulking and Sealants (silicone, parbond, vulkem & more) Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 266 07-01-2017 11:41 AM
Parbond or Gutter Seal for Exterior Seams??? mwmoss Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 02-23-2005 08:36 AM
Parbond Illegal in California... Safari Tim Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 12-16-2004 05:14 AM
Sikaflex, Vulkem, and Parbond Questions JohnG Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 07-27-2004 08:06 PM
ParBond Shrinkage? Jabba Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 08-11-2003 01:12 PM
