Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 12-06-2007, 07:39 AM   #1
Aluminati
Profile:  1968 26' Overlander
Ann Arbor , Michigan
Images: 11
Working on AS in winter.
I have started working on my 68 Overlander. I have gutted out everything except for the bathroom and kitchen sink...which I plan to do this weekend.
The issue is I am in Michigan and it is COLD!
There are a few very important things I need to address ASAP!
When working inside I will get a propane heater attatchment so I can have some heat while working.
Should this be enough?
One is the leak that I have and the other is putting in a new floor.
The leaks.
Leaks. From the top...I know it is leaking from one of the plastic vent covers. it is cracked and has a leak...I have seen it with my own eyes...dont know how to fix. Can I just pick one of these up at an RV dealership?
Two front windows. I can see ice on the inside rails. I dont know where it is leaking from...how can I find this...in the cold. I can just throw water on the trailer because it will freeze. Does anyone know where it would be leaking from...it is the front window on the righthand side of the door and the window directly accross from it.
Floor rot.
I noticed that the floor is soft around some of the edges...as well as rotted through behind the wheel well. Does this mean that I have a leak behind the wall or is this just normal for a 68?
The floor looks like it needs to be replaced about 6 inches around most of the trailer. Being that I am putting restaurant equipment in there...i need to replace the floor...but I dont want to replace the floor without fixing the leaks.
Any suggestions.
Aluminati is offline   Reply With Quote
Old 12-06-2007, 10:49 AM   #2
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Are you talking about a propane heater other than the furnace?
Are you ready to sufficate?
If you are going to use a unvented heater in a confined space stick to electric.
Michelle
Think you are having a bad day? Go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 12-06-2007, 11:22 AM   #3
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Checking for leaks is an endless task until you find a dealer with a Sealtech tester. For more info see http://www.airforums.com/forums/f335...ent-36889.html
AC should not working hummerdinger Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-21-2007 10:42 PM
Working on it.. Catfisherman 1975 Sovereign 0 01-30-2004 08:28 PM
Pm Not Working Inland RV Center, In Our Community 9 05-05-2003 08:04 PM
