Old 03-02-2008, 03:38 PM   #1
1970 31' Sovereign
Collierville , Tennessee
Window weather stripping????
I just checked and all my windows gaskets are shot! I found the "double flap" and "d" weatherstripping. Can this just be "pushed" in to install or do you have to do anything else? I haven't found any info on how to replace and now I can't go out and look becuase the AS is 90 miles away. I need to go ahead and order for next weekend.
TN-TUNDRA is offline   Reply With Quote
Old 03-02-2008, 04:17 PM   #2
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
I am facingthe same issue. I've pulled all my windows and removed the film (nasty) but gaskets all need replacement. Take plenty of pics as you do this so lazy ones like myself can benifit from your pain I did do somthing different a while back that seems to have had a good payoff. I drilled drain holes in the window sill body. Can't really see them unless you have the windows open but they did help manage water leakage quite nicely. With the windos closed, the holes are not visable. I will need to nip the lower gasket when I install fresh ones, but the old ones do not seal up the holes even with the window closed tight.
rob
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 03-02-2008, 04:36 PM   #3
1970 31' Sovereign
That is a good idea about the drain holes. One of my windows had about and inch of standing water in it after I opened it. I'll take some photos of the fix. But I don't want to have to remove rivets and re-rivet If I don't have to.
Old 03-02-2008, 04:38 PM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Take a look at my site, I have a page on what I did, hope this help...??
Weather Strip Maintenance
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-02-2008, 04:50 PM   #5
1970 31' Sovereign
That's what I wanted to know. Thanks A LOT!!! Now I'll order some weatherstripping. Abot how many feet did you use?
Old 03-02-2008, 05:22 PM   #6
rob
Drain holes serve no purpose one trailer opening windows.
The original double flap gasket worked well fo many years, but we came up with a "D" shaped gasket that does a superior job.
Very easy to install, as well.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-02-2008, 05:23 PM   #7
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
About 7' per window, I like to add about 10% for cutting and error...
Did you look here for your style?
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
They have been a great asset for me!
www.balrgn.com
Old 03-02-2008, 05:44 PM   #8
1970 31' Sovereign
I have used them before. I didn't see the correct gasket there. I need a few other items and will be calling Inland tommorrow.
Old 09-02-2008, 01:45 PM   #9
1975 31' Sovereign
Durango , Colorado
My 75 sovereign fixed windows are leaking. Any advise on how to repair without pulling the entire window out?
bbmombo is offline   Reply With Quote
Old 09-02-2008, 01:47 PM   #10
1975 31' Sovereign
Durango , Colorado
Exclamation 75 sovereign fixed windows leak
Any advise on how to repair the fixed windows that leak??
Old 09-02-2008, 02:06 PM   #11
Purchase some Vulkem sealer. "CLEAN" the metal to glass seam, "VERY WELL".
Apply a nice bead of Vulkem that bridges the metal frame and the glass.
That repair will last a long long time and will never leak, if you do it right.
You should also apply a bead of vulkem to the top and both sides of the fixed windows. Again, a clean surface, is a must.
Now the only fixed window leak you might have, is if the glass breaks. The vulkem won't help that problem.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-02-2008, 07:09 PM   #12
1973 31' Excella 500
Morristown , Tennessee
Similar story to many others but here goes for the sake of repitition. I have a 1973 Excella and probably paid a little too much but it is completely original. Something important for me.
The floors were solid except for one place under the rear nightstand (rear double) and couldn't be seen until it was removed. The other place was right around the front door. It was obviuos that the weather stripping was shot. I called Andy at Inland RV and had the right stuff shipped. I took out each window, cleaned the edge and applied new weather stripping with sealant. It didn't take too ling and I have not seen a drop in the bos after several hard rains. The most difficult part was getting the windows back in the track. It would help to have an assistant expecially for the big ones. I was not very scientific about it. I just kind of eye-balled it and cut the excess with a razor knife. I only wasted inches at most. The door was the most difficult since it could not be removed.
It was the most satisfying job I've done so far. Great guys a Inland RV. Try to order everything you need at once. It is like receiving an early Christmas package.
Joe DeFelice
1973 Excella 500
Alumin8 is offline   Reply With Quote
Old 11-27-2008, 05:17 AM   #13
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Should you use the gasket with the Vulkem?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 11-27-2008, 05:19 AM   #14
1977 31' Sovereign
Images: 33
What kind of gasket should I use for my trailer?
K/N Cool intake air
Duel power exhaust
Old 11-27-2008, 06:21 AM   #15
Gasket is not used between the glass and metal frame of the fixed windows.
A "D" shaped gasket, #45370 is used on the back side of the opening window and the entrance door, as well as the access doors.
If your in the gasket replacing mode, check the sewer vent pipe gaskets. They have a life span of 5 years or so.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-18-2008, 05:06 PM   #16
TPdrums's Avatar
1972 27' Overlander
Mo Hill , California
On the topic of Gasket replacement and leak control. I have two top mounted Vista View Windows that both have really bad leaks. I am assuming that I can take out the mounting screws, the glass will fall back- into the trailer, and then I can clean and prep the frame for new Butyl tape before replacing the glass and securing with the screws. Is this right? has anyone done this one before?
www.ToddCreatedWood.com
TPdrums is offline   Reply With Quote
Old 12-18-2008, 07:15 PM   #17
You don't need to do that.
Clean the glass to metal junction, so that it's chemically clean.
Apply a nice neat bead of Vulkem sealer to the glass/metal junction.
That sealing job will out last you.
Andy Rogozinski
Inland RV Center
Corona, CA
weather stripping Londoner Windows, Doors, Locks & Vents 7 07-13-2008 08:03 PM
Weather stripping BB 55 Bubble Windows & Screens 4 03-15-2006 12:04 AM
weather stripping wagongirl Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 04-28-2005 05:01 AM
window weather stripping squeeky Windows & Screens 1 03-14-2004 10:32 AM
Window Screen Weather Stripping ??? niftypkg Windows & Screens 0 06-03-2002 06:28 PM
