Old 11-27-2008, 06:21 AM   #15
Originally Posted by Mrcrowley View Post
What kind of gasket should I use for my trailer?
Gasket is not used between the glass and metal frame of the fixed windows.
A "D" shaped gasket, #45370 is used on the back side of the opening window and the entrance door, as well as the access doors.
If your in the gasket replacing mode, check the sewer vent pipe gaskets. They have a life span of 5 years or so.
Old 12-18-2008, 05:06 PM   #16
TPdrums's Avatar
1972 27' Overlander
Mo Hill , California
On the topic of Gasket replacement and leak control. I have two top mounted Vista View Windows that both have really bad leaks. I am assuming that I can take out the mounting screws, the glass will fall back- into the trailer, and then I can clean and prep the frame for new Butyl tape before replacing the glass and securing with the screws. Is this right? has anyone done this one before?
Fine Woodworking, Furniture, Carpentry, Drums, and Lutherie
www.ToddCreatedWood.com
http://toddcreatedwood.blogspot.com/
TPdrums is offline   Reply With Quote
Old 12-18-2008, 07:15 PM   #17
You don't need to do that.
Clean the glass to metal junction, so that it's chemically clean.
Apply a nice neat bead of Vulkem sealer to the glass/metal junction.
That sealing job will out last you.
weather stripping Londoner Windows, Doors, Locks & Vents 7 07-13-2008 08:03 PM
Weather stripping BB 55 Bubble Windows & Screens 4 03-15-2006 12:04 AM
weather stripping wagongirl Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 04-28-2005 05:01 AM
window weather stripping edgybrown Windows & Screens 1 03-14-2004 10:32 AM
Window Screen Weather Stripping ??? niftypkg Windows & Screens 0 06-03-2002 06:28 PM
