Old 03-22-2012, 04:34 PM   #1
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
window seals tearing.
Replaced all the window seals on our 66 Safari, got them from the west coast Airstream guru. That was last fall, since then they have been closed all winter, and up until today. When I cranked each window open today the seal was stuck solidly to the window glass. As I worked my way around each window I was was able to get them all opened without glass issues ( thank you LORD, as these are all frameless windows.)
BUT... every single seal torn a bit where they made contact. Now then I'm thinking this can't be the first time it's happened, so where to go from here? The seals are all good , but I'm thinking I need to grease the rubber with something so it doesn't stick, yet I don't want this to be a dust /bug collecting mess either. Anyone.. what do I use?
Thanks as always for the brilliant answers that are to come...
Karen & Barry in Mich.
goshawks00 is offline   Reply With Quote
Old 03-22-2012, 04:39 PM   #2
Spray all the gaskets with "Silicone spray".
Use it to completely cover each gasket, very well.
Then close the windows.
After a week or so, open the windows and wipe the excess silicone spray off.
Do that to the gaskets once a year or so.
Always coat brand new gaskets to avoid the sticking issues.
Old 03-22-2012, 04:44 PM   #3
Baltimore , Maryland
Is it square or is it "d"?
Is it foam or is it rubber?
Old 03-22-2012, 06:19 PM   #4
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
It's square and I believe it's foam rubber ( sorry not sure). I wish I would have gotten that advice about the silicone ( probably did and old timers allowed me to forget it) when I installed them... Thanks Andy...
Old 03-22-2012, 06:35 PM   #5
Foam gaskets are not for window seals, nor should they be flat.
How about posting a good photo?
Old 03-22-2012, 08:09 PM   #6
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
I am pretty sure I got them from you though I may be wrong..how about posting a pic of what they should look like. Thanks for the advice about the silicone spray.
Barry
Old 03-22-2012, 08:58 PM   #7
Barry
I cannot post a photo, since I am in Hawaii.
But look at our part numbers 45295 and 45370, that are listed in the parts section of our web site, Inland RV Center - The Nations Leading Expert in Airstream Innovations.
Those are the only 2 window gaskets we have ever sold.
Please list your invoice number and we will check on what we sent you.
Old 03-30-2013, 07:38 AM   #8
Steinmetzmr's Avatar
Medina , Ohio
I assume these products are sold by the foot. On average, how many feet to do all the windows? And how many feet for the door?
Steinmetzmr is offline   Reply With Quote
Old 03-30-2013, 07:49 AM   #9
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
The amount you need depends on the number of windows! What trailer do you have? Door is 16 feet.
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 03-30-2013, 08:02 AM   #10
Medina , Ohio
I have a 1972 Overlander . Thank you for the door info!
Old 03-30-2013, 09:31 AM   #11
1974 Argosy 20
Kooskia , Idaho
Fantastic Fan also has a seal lube for their fans, so the lid does not stick to the rubber. It might also be a product you could try, but if Andy says Silicone, I am sure it will work fine.
Old 03-30-2013, 11:03 AM   #12
The following is the number of feet of gasket needed for the 1969 and up trailers.
small window 7 feet
med window 9 feet
large window 11 feet
front and rear windows 12 feet each
entrance door 16 feet
rear compartment door 9 feet.
most other compartment doors 6 feet
One tube of adhesive for each 25 feet of gasket which is 50 feet of surface application. 25 feet on the gasket and 25 feet on the metal framing.
Old 03-30-2013, 01:46 PM   #13
Medina , Ohio
Thanks, that gives me a better idea of what I am dealing with.
Old 04-16-2013, 05:07 PM   #14
Medina , Ohio
small window 7 feet
med window 9 feet
Trying to order from Inland RV , been trying for 15 minutes and no one answers the phone or is busy. No hours of operation listed, would like to order why no online ordering?
Round window (porthole). Would this work? timzog Windows & Screens 27 11-16-2012 09:01 AM
Wheel Bearings/Races & Seals 1958 18' REDSLED88 General Repair Forum 17 03-25-2012 10:03 PM
Window Extrusion ? DontBSilly Windows & Screens 16 03-21-2012 07:04 PM
310 window latches montreal Classic Motorhomes 4 03-20-2012 12:55 PM
Front Window Support arm pickerdd Windows & Screens 2 03-20-2012 05:53 AM
