Old 04-11-2007, 12:06 PM   #1
Devils Lake , North Dakota
Window Sealant
As a semi retired body person I am wondering what is the standard product you use to re-seal windows??? A product used in auto is butyl rubber in roll form. It is used in non-structural windows. I assume the trailer windows are not structural and urethane sealant would me a pain to remove down the road. Does anyone or has anyone, used butyl tape??
Sundance is offline   Reply With Quote
Old 04-17-2007, 07:39 AM   #2
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
I may have just bought some yesterday from NAPA. I went there looking for butyl tape. They couldn't find any, but referred me to "windshield sealer" or something like that. 3M calls it "Windo-Weld Ribbon Sealer" it's PN:08611. 5/16"x15' round bead. It's black. I went ahead and bought it.
I was planning to use the butyl tape for sealing under the Fantastic fans that are going in sometime soon.
Are you referring to using it for reseating the glass pane within the window frame, or if you have thermopanes, then between the two glass panes and the frame? What's currently installed in my windows is greyish colored.
There was recently a thread on here about someone who was taking apart their windows and cleaning them up and then replacing this stuff.
I agree with you, the windows themselves are not structural.
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 04-17-2007, 07:50 AM   #3
Images: 59
Vintage Trailer Supplies has window bedding tape 1/16" x 1/4" x 50 ft for $8. It's made of isopolybutylsomething.
Old 04-17-2007, 11:28 AM   #4
Yes both those are "butyl" tape and redily available at
any local body shop supply house.
I am refering to rebedding the window frames and not
the thermo panes (wish the Arogosy had them!!)
Old 04-21-2007, 07:13 AM   #5
Wow it appears you have to remove rivets to rebed the window??? I'll pass on that and use Acryl-R myself.
Old 04-21-2007, 09:35 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Butyl bedding tape is also available at most RV supply houses, HVAC supply houses and metal/roofing suppliers. There are some minor differences in the formulation but shouldn't make any difference in this application. It also comes in varying widths and thicknesses. I have a couple of rolls floating around here that are 3" wide But I think on the Airstream the best stuff would be the 3/4"x1/8" or the closest to that you can get. BTW real fun stuff to work with on a 100+ degee day
Aaron
WBCCI #XXXX AIR #2495
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 10:00 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
