Window seal leaking ??????
I guess it's my turn for the age old ( or Airstream Old ) issue of leaks. It seems that just to the right of the entry door is a non-opening window. It originally was a double paned one but someone in it's prior life had removed the inner pane. Probably due to its inner seal leaking and the window fogging. That's another story. On the outside there seems to be a piece of aluminum trim that's rivited to the body with a seal of some sort to make it weather proof. I see some gaps in the glass / seal line and they are significant and need to be sealed. I have some sealer that I used on the roof when I installed new vents. Is that good for the window application or is there something more appropiate I can use. The original seal between the glass and trim appears to have been a solid material rather than a caulking type. It has leaked onto the floor and will require me to remove some of the flooring and replace. But that's another thread and issue.
Thanks all,
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
