Old 03-29-2010, 11:43 AM   #1
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
window seal 'grease'?
I know I've seen this on the forum before but can't find it. Isn't there some sort of lubricant that I can put all around the strips under my windows so that when my windows stick and I'm trying to open the windows they won't shatter? Right now I'm slipping a plastic knife blade to gently pry them open, but I'm nervous doing that.
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
kfrere is online now   Reply With Quote
Old 03-29-2010, 11:49 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
I have read that silicone spray - Google Product Search is used on window seals so they won't stick.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-29-2010, 11:57 AM   #3
dstalzer's Avatar
2005 25' Classic
I have used silicone spray that I purchased at Lowes on the rubber gasket and it keeps the windows form sticking. I have had to repeat this about once a year. The plastic putty knife is also my method if a window does stick.
Dennis
dstalzer is offline   Reply With Quote
Old 03-29-2010, 12:04 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Here's a thread -- the whole thread is worthwhile but the post linked gives probably the best product -- http://www.airforums.com/forums/f454...tml#post439162
5 meter Langford Nahanni
Old 03-29-2010, 12:40 PM   #5
Chasmorgan's Avatar
1999 23' Safari
Someone mentioned a light coating of vaseline.
Chasmorgan is offline   Reply With Quote
Old 03-29-2010, 03:27 PM   #6
richinny's Avatar
2011 34' Classic
if you still have a problem after the silicone use a plastic knife on both lower corners at the same time. this will keep the flexing to a minimum. apply increasing pressure gently and evenly.
Ricky
Old 03-29-2010, 04:49 PM   #7
Exterior lube
Silicone spray, is used for many things on the exterior.
Lubing the window, access door and entrance door gaskets, is a semi annual PM.
Lubing the entrance door striker bolt and pocket, is a PM as needed.
Lubing the entrance door hinges, is another PM, as needed.
Lubing the LPG hold down "T" handle is another as needed PM.
Lubing the footstep is a good PM.
Other types of lubes for the exterior of an Airstream, generally speaking, run a distant second to "silicone spray".
Old 03-29-2010, 04:55 PM   #8
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I use silicone spray since I have some and it works pretty well. I keep a metal putty knife in my tool box—it has many uses—and gently loosen the bottom of the windows when they stick. They are stronger than you think, but it's still good to be gentle.
Airstream specifies certain different types of oils for other things like hinges in the owner's manual.
Gene
Old 12-16-2010, 05:12 PM   #9
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Thumbs up Gummi Pflege
This is what I use on my BMW weatherstripping. Keeps it fresh and pliable.
Turner Motorsport - Item# 08930128 - Wurth Rubber Care (Gummi Pflege)
It has a nice circular applicator that cleans and applies the silicone to yhr seals and weatherstripping.
Lance
Top is offline   Reply With Quote
Old 12-16-2010, 05:14 PM   #10
dznf0g's Avatar
Oswego , Illinois
I use 303 Protectant. No sticking so far. We'll see after staying closed up in storage for 5 months.
Old 12-16-2010, 06:19 PM   #11
r carl's Avatar
Lin , Ne
Di-Electric grease has many uses around a camper.
Old 12-16-2010, 10:46 PM   #12
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I don't use anything because the so-called cheap Safari windows don't have that problem.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-17-2010, 09:20 AM   #13
2010 27' FB Classic
N/A , Texas
I agree!
How often to coat them depends on if your windows are subject to sunlight and heat. The more exposed to sun and heat the more often you need to coat them. It's also good to use 303 on the Fantastic vent rubber to keep it from sticking.
The sticking problem, in my case, is less of a problem as time and coats of 303 are applied.
Old 12-17-2010, 09:23 AM   #14
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Bluto View Post
I agree!
Yup, me to, as well as applying directly to shylights, vent covers, interior plastic window surrounds, tires......anything rubber or plasic which takes a sun beating.
Grease seal P/Ns TomW Axles 8 11-10-2012 06:13 PM
Grease seal availability Inland RV Center, In Commercial Listings 0 04-09-2009 02:20 PM
'57 Grease seal #? 3Ms75Argosy Axles 1 10-13-2008 08:34 AM
grease seal for 2006 Safari SE 25' mistermcfrug General Repair Forum 2 09-06-2007 07:43 AM
Specific Grease Seal Model AirSpleen Axles 4 11-29-2006 01:15 PM
