Old 04-09-2006, 09:02 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Window lift lever fuzzy stuff
Where does one buy relacement stuff that goes around the windown lift levers when they are open. Mine are shot and bugs could come right in.
wacnstac is offline   Reply With Quote
Old 04-09-2006, 10:41 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Mine, too. Need fuzzy stuff!
Old 04-10-2006, 12:47 AM   #3
1992 34' Limited
Falls Church , Virginia
Clarification attempt - again!!!!
Are we talking about the 'furry strip' that sits on the left and right of all opening windows. There is a slit within the 'fs' allows the window mechanism to be inserted and to slide freely up and down, ie opporate a window.
Is this what we are all talking about!????????? Hope so.
If not, then we need a LOT more detail to specify exactly so that there isn't needless searching.
Axel
SilverToy is offline   Reply With Quote
Old 04-10-2006, 01:55 AM   #4
The window fuzzies are available from Inland RV. I've replaced all mine. It's a fiddly time-consuming job, and it seem's expensive, until you remember the bugs.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 04-10-2006, 05:36 AM   #5
Images: 43
That's what I'm looking for. What makes the job so time consuming?
Old 04-10-2006, 06:25 AM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
If you are lucky enough to have a local window shop that manufactures windows or even does custom work stop over there. This is a very inexpensive item and they will probably cut off a length for you if you smile. I was able to get all of the fuzzies I needed when replacing the screens in my Tradewind. Also if you have an account with CR Lawrence they will send it to you in a great big roll.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 04-10-2006, 10:45 AM   #7
Each window inner frame and the accompanying knobs on the levers have to be removed (lots of self tapping screws, which I have replaced with stainless steel bolts and nyloc nuts). The old fuzzies are pulled off, but then all the old glue has to be carefully removed by scraping and using a suitable solvent, perhaps acetone. The fuzzies are applied with contact adhesive, so there is just one chance to get it right. With seven opening windows, 14 fuzzies, this was a long task.
Nick
Old 04-10-2006, 11:52 AM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
you can also get the fuzzy seals from any airstream dealer.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Chuck is online now   Reply With Quote
Old 04-20-2006, 09:22 AM   #9
Angel73's Avatar
1975 31' Sovereign
Woodlawn , Tennessee
Images: 65
Send a message via Yahoo to Angel73
thanks
Ill try that thanks.Just replaced all my screens now on to the fuzzy stuff and the seals around the windows. anyone know where i can get this and what is called if u go to my pic on here your'll see the windows part thats in great need of replacing
Angel73 is offline   Reply With Quote
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Fuzzy Window Seals Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 34 07-21-2010 02:53 PM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
