Old 04-07-2006, 07:56 AM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Question Window leaks, where to start?
1979 31' Iternational. It is raining here again today and my airsteam is leaking again. If I look at the windows near the dinette and pull the plastic shroud back around the little windows underneath, I can see a lot of water sitting on the aluminum shelf just below this window. Leads me to believe I have a leaky window problem which is pretty severe. Could confirm once it stops raining with a hose. Where to start with windows?
wacnstac is offline   Reply With Quote
Old 04-07-2006, 12:42 PM   #2
Images: 43
Window experts? Anyone? Do I start on the inside by removing the plastic trim around the smaller lower windows? Start from the outside? The caulk from the outside seems to be there and in fairly good shape.
Old 04-07-2006, 12:54 PM   #3
Vista view and stack windows were sealed by Airstream using the infamous "silicone sealer".
Remove all traces of it. Apply a bead of vulkem sealer over the gray gasket material. That will give you a positive seal between the glass and the metal frame.
CAUTION: You "MUST" remove all traces of the silicone sealer. If not, the vulkem will not correctly bond.
Old 04-07-2006, 12:57 PM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
I just peeled (with a heat gun) all the Vulkem (factory) from the windows below my Vista Views, I had several cracks in it from age. Re-applied new Vulkem along the top seam. Once it was off, there was evidence that water had trailed in through there..
I would not go after the inside before I try real hard to find it outside, that is where the water is coming from.....
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-07-2006, 01:06 PM   #5
Images: 43
Forgive me for my Airstream ignorance but the larger windows are the "stack windows" the bigger windows, and the smallers ones below them called "vista"?
Old 04-07-2006, 01:28 PM   #6
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Talking Hopefuly former leak
Hope this helps...
www.balrgn.com
Old 04-07-2006, 01:54 PM   #7
The "vista view" windows are above an opening window.
The "stack" windows are below the opening windows.
Old 04-07-2006, 01:58 PM   #8
Images: 43
It appears my problem is the stack window, but I wouldn't rule out the opening window either.
Old 04-07-2006, 03:13 PM   #9
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Mine was or I beleive it wason the middle one. There we singns of water beneath the sealer.
www.balrgn.com
Old 04-08-2006, 07:00 AM   #10
Images: 43
There is definitely some bad joints around the windows. Do you guys use vulkem to caulk between the window itself and the aluminum frame here?
Old 04-08-2006, 07:38 AM   #11
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
wacnstac,
What I did in that situation was to cut the "plastic" back with a sharp razor knife, clean thoroughly and lay in a bead of vulkem. I used the blue masking tape to keep the vulkem mess to a minimum and to give me a uniform bead.
In retrospect I should have made my bead a bit wider than my pictures show, the Vulkem does shrink a bit. However the leaks have gone away
Aaron
Name:	Window Seal 1a.JPG
ID:	20258   Click image for larger version
Name:	Window Ready to Caulk 2a.JPG
Name:	Finished Producta.JPG
WBCCI #XXXX AIR #2495
Old 04-08-2006, 08:26 AM   #12
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Originally Posted by balrgn
Mine was or I beleive it wason the middle one. There we signs of water beneath the sealer.
After more rain, still leaks, less tho, I may be getting closer to the source(S)
I did not use Vulkem between the windows. I was lucky and the inside window pops out. I used window calking that came on a roll. Vulkem out side.
I did find that my window latch was not closing tight enough as well. Had to machine a lock nut to keep it tight, the threads have worn in the where the nut tightens to the locking bar.
www.balrgn.com
Old 04-08-2006, 11:42 AM   #13
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Critical here too is to use Parabond in the mitered corner on the window frame. On your first picture of the wrap window that would be the upper and lower joint on the left side of the wrap window's frame.
Otherwise I did the same as you except it did not turn out so pretty , however the best I can tell the leaks have stopped
One more think to mention. I replaced both of my missing wrap windows with lexan. While it works it tends to flex and I think that causes the vulkem seal to break while under tow. I don't know if glass has the same reaction or not. I push on the lexan while looking at the seams and when its failed you can see it seperate and thats where the water enters.
You can also push on other parts of the trailer and watch for seperation like at the vent covers or lower trim above the bellywrap. If you push on the aluminum and see the seal give way, its a good indication water will get in.
Originally Posted by wahoonc
wacnstac,
Aaron
-Tim
theVAP - Airstream Podcast
Old 04-08-2006, 12:13 PM   #14
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Tim,
Right you are about the Parbond, I forgot about doing that. We these vintage units you got a tube of caulk in hand and you just start putting it in and forget all of the places you did put it. I even took the front rock shield off and redid it. Good thing there were several holes behind the hinge that were leaking. Put rivets in them to blank them off, then used butyl tape sealant and vulkem on the re install. After I finished with the rock shield and the wing windows the leaks in the front went away, then it was on to the Vista Views....
Aaron
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
