Window leaks in '52 Cruiser
We're rehabbing a 1952 Cruiser but need some window work. I want to re-set all the windows with new vinyl gasket material but can't find how to disassemble the frame to put in the new vinyl.
I'm starting with the bottom window ay the entry door. I have the frame out. The frame is slit in the top center allowing us to pull it away from the plexiglass. But it won't allow us to pull it apart all around the frame without it bending/twisting. So we can get the frame loose from the top and half-way down each side, but no further for fear of bending or twisting it/
Any clues will be appreciated.
Bob K, Warrensburg, Illinois
