Patti, You most likely have the Hehr Hall Mark-12 windows. You'll need the glazing strip that comes in a 12' length and the window bulb seal. Look for items that are listed for the Hehr Hall-Mark 12 windows, since that is what you have. This will seal the windows. If there are other leaks, it may be from a seam that needs sealing from the exterior of the coach. Good luck in repairing your leaks.
__________________ Kevin with Baity the Lab/Pointer //------AIR # 7303------\\ WBCCI 17109 visit my restoration blog at: |
