Old 04-03-2009, 08:11 PM   #1
1972 31' Sovereign
Dalhousie Junction , Canada
Window Gaskets; How many feet?
Hi , I have a 1972, 31' Sovereign and have to change all the gaskets on the windows and door. Does anyone know how many feet of gasket I'll need and is it the "D" type. Now that it's spring it's finally time to get to work on my restoration project! Thanks to all who reply!
Pkerr is offline   Reply With Quote
Old 04-03-2009, 10:15 PM   #2
The "D" type is a superior upgrade from the original.
You have 8 windows that open, plus the entrance door and access compartments.
I have a chart at my office that tells us "how many feet," but right now I'm home.
Old 04-05-2009, 09:18 AM   #3
1972 31' Sovereign
I read that it takes 7' per window.Not sure if it applys to my model though.
Old 04-05-2009, 11:25 AM   #4
You heard wrong for your Airstream.
5, 6 and 7 feet was used on the 66, 67 and 68 models.
As an example, a medium window on your trailer is 20 1/2 inches by 29 inches.
That's 99 inches, or for one window, 9 feet.
Gasket is sold by the "foot."
Old 02-04-2010, 08:17 PM   #5
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
I have a 1970 International 27'. What type of gaskets do I need for the baggage doors? I have 3 fridge, battery and rear and the entry door. Also, should I use the same on the windows? Thanks ALL!!
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 02-04-2010, 08:29 PM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Original gaskets for the windows and the doors.
Window and Door seal 682520 [682520] - $0.79 : ODMRV , Out-of-Doors Mart
Some will recommend the newer D shaped gasket as a replacement and it is easier to install. Personally, I liked it on the side access doors - I did not like it on the windows.
Also installed it on the rear access door and ended up removing it and going back to the original - in my case it sealed better.
Old 02-05-2010, 02:25 AM   #7
Yes.
The "D" gasket is superior to the original.
Instructions to properly install it are simple.
I cannot tell you how many feet as I am out of town until 2-15.
Old 02-05-2010, 06:02 AM   #8
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I ordered mine from Inland, and they sales person was able to look it up how much I needed for our '97 34' Excella very quickly.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 02-05-2010, 06:41 AM   #9
Whirlaway's Avatar
2008 27' Classic FB
Anytown , Massachusetts
Will the "D" window seal work on 2008 Classics?
When I went to the website listed a few post before I see no listing for newer models. Does this work on those models too?
Life Is Not A Dress Rehersal
It's okay to have too much fun
WBCCI #8701* TAC MA-1 * NEU UNIT
Gracie...A Liver & White GSP
Get busy livin', or get busy dyin'." - The Shawshank Redemption
Whirlaway is offline   Reply With Quote
Old 02-05-2010, 09:02 AM   #10
Yes.
The "D" gasket will work on any Airstream trailer windows, from the 50's to current models.
Old 02-05-2010, 09:45 AM   #11
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Great, Just what I needed. Thanks Guys!!
Old 02-06-2010, 09:59 AM   #12
Whirlaway's Avatar
2008 27' Classic FB
Andy thanks as always....
Originally Posted by Inland RV Center, In View Post
Yes.
Outstanding.
Old 02-06-2010, 11:59 AM   #13
Depending on the year of the trailer, the gasket is attached to either the glass frame, or to the part that's riveted into the shell.
As an example, for the windows that used the "thin gray domed gasket", you can improve the gasket performance by installing the gasket on the metal frame that's riveted into the shell, instead of on the window frame itself.
Old 02-06-2010, 12:12 PM   #14
The original gray domed gasket used way back then, was a way to seal the window from rain, well..... sort of, if you have a huge imagination.
Today, that bulb gasket is a joke, and a bad one at that.
It permanently compresses to a flat surface in a matter of a couple of months.
The "D" gasket, does not have that same issue, and does a superior job sealing the rain out, even at highway speeds.
Window Gaskets Robin Stone Windows & Screens 6 03-06-2008 04:11 PM
Window gaskets? rebel beck Windows & Screens 9 09-12-2006 01:22 PM
63 Safari Window gaskets srgntpepper Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 05-21-2005 03:39 PM
Adhesive for window gaskets Tin Hut Windows & Screens 15 10-03-2004 09:19 PM
Replacing my window gaskets Bigdog Airstream Motorhome Forums 1 12-12-2003 01:57 PM
