Old 02-20-2010, 02:00 PM   #15
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
Window gasket repair query
I have a window where the gasket has lost its adhesive in one corner and pulled back to run kitty-corner instead of making the 90-degree turn, if that makes sense. The gasket makes a good seal around 90% of the window but has pulled away from the one corner only. So should I take the whole gasket off and start over instead of trying to stretch it back to cover its intended path. Or if I can just tack the bad corner back down, what should I use to adhere it and how would I hold it in place while the adherent cures? The gasket is in good shape so my guess is I can repair it but what's the best course of action? -- John
JBinKC is offline   Reply With Quote
Old 02-20-2010, 03:08 PM   #16
Remove the complete gasket and destroy all of the old adhesive.
Reinstall the gasket with 3 M Super Weatherstrip adhesive. ONLY. It's black. The yellow stuff is no good for your purpose.
Old 02-20-2010, 03:29 PM   #17
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Originally Posted by Ganglin View Post
Original gaskets for the windows and the doors.
Window and Door seal 682520 [682520] - $0.79 : ODMRV , Out-of-Doors Mart
Some will recommend the newer D shaped gasket as a replacement and it is easier to install. Personally, I liked it on the side access doors - I did not like it on the windows.
Also installed it on the rear access door and ended up removing it and going back to the original - in my case it sealed better.
Why did you not like it on the windows?
bwaysteve is offline   Reply With Quote
Old 02-20-2010, 04:12 PM   #18
1960 24' Tradewind
Riverside , California
That's not the correct gasket for his trailer, the Classic uses a half circle neoprene ("D") The gasket you quoted is used on the 1969 and newer glass & sash windows. The black 3M super weatherstrip adhesive won't showup on the edges like the yellow
Greg
ZoomZoom is offline   Reply With Quote
Old 10-29-2015, 02:56 PM   #19
nickclifford's Avatar
1972 31' Sovereign
felton , California
Originally Posted by Pkerr View Post
Hi , I have a 1972, 31' Sovereign and have to change all the gaskets on the windows and door. Does anyone know how many feet of gasket I'll need and is it the "D" type. Now that it's spring it's finally time to get to work on my restoration project! Thanks to all who reply!
question on the D gasket, I ordered a whole load for every window on my 31' Sov, it's TOO wide for the frame ?? I don't see how this can be sold for the windows . any thoughts, much appreciated !
nickclifford is offline   Reply With Quote
Old 10-29-2015, 03:15 PM   #20
airstream apparently used more than one supplier for the window frams (sash).
The small "D" gasket is wider by 1/16 of an inch. If the gasket is placed against the wall of the sash, that's the vertical part, on occasion a small overhang will take place.
If that happens, there is not much that you do except, if you wish, live with it. WHY?? Because it's many times superior than the original double flanged gasket. That's why Airstream has switched to it as well.
It causes no harm or problems in any way as far as doing a very good job of sealing the window sash.
Each year we go through about 5 miles of it, and have not heard of any overhang issues, ever, except in your case.
That "D" gasket is expected to out last the double flanged gasket, hands down.
Finish the installation, then have a couple of "cool ones" and enjoy your Airstream.
By the way, did you replace the sewer vent pipe covers, that only last 2 to 3 years.
Old 10-29-2015, 05:38 PM   #21
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Window Gaskets; How many feet?
I ordered and used about 100 feet on the nose for my 1972 31'er.
This is enough for all of the windows and the door, but don't get careless.
The "D" gasket that Inland sells fit my frames perfectly, or at least perfect enough to satisfy me.
Brevi tempore!
Old 10-30-2015, 11:16 AM   #22
1972 31' Sovereign
felton , California
Andy, how can that be out of interest though? My AS is stock, the windows are stock and from the picture we can clearly see an overhang ! I can't possibly be the only person to have discovered that this gasket is too broad for the window fitting ! I have no doubt it's a great product and will give it a go !
I've read you suggest using an electric drill with circular brush to remove old rubber that's hardened on. Some people suggest removing the window, I'd prefer to avoid if possible !
Old 10-30-2015, 12:50 PM   #23
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Taking the frame and window off the trailer is going to be the way to do the job right, taking the glass out of the frame would be insanity.
Brevi tempore!
Old 10-30-2015, 12:59 PM   #24
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
There are places where it hangs over the edge, but for all practical considerations it is a moot condition.
It fits nicely in the window opening.
Name:	ImageUploadedByAirstream Forums1446231446.756206.jpg
Fwiw, resist any urge to stretch the strip to make it more narrow.
Brevi tempore!
Old 10-30-2015, 03:16 PM   #25
Do one window, your way.
Then, remove the window and do it the vast majority way.
I feel sure you will finish the task, by removing the windows, as it's so simple to do, and most i,portantly, you won'y have a need to do work that's over your head.
Old 10-30-2015, 04:16 PM   #26
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
And beside that, if the window does not come off the trailer it will be impossible to clean the top edge and to put the gasket on properly.
The window and its frame must come off.
It is easy to get them off, two nuts on the window props, and lift the bottom of the window and it will actually fall off.....
There is a little technique involved in getting the tongue back in the groove on reinstallation, but it isn't hard.
Brevi tempore!
Window Gaskets Robin Stone Windows & Screens 6 03-06-2008 04:11 PM
Window gaskets? rebel beck Windows & Screens 9 09-12-2006 01:22 PM
63 Safari Window gaskets srgntpepper Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 05-21-2005 03:39 PM
Adhesive for window gaskets Tin Hut Windows & Screens 15 10-03-2004 09:19 PM
Replacing my window gaskets Bigdog Airstream Motorhome Forums 1 12-12-2003 01:57 PM
