Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 02-21-2009, 12:25 PM   #1
reggiemon's Avatar
Profile:  1959 18' "Footer"
Corpus Christi , Texas
Smile Window drip rails sealant
Hi,
What is the best sealant to use when replacing the drip rails over the doors & windows? Buytal tape or Vulkem?
I need to take the front & back drip rails off to seal the tops of both window frames with Vulkem to stop leaking
Also I have some that are attached with SS screws. Should I go back & rivit them? PO put plumbers putty under them.
Thanks!
1959 "Globester"
reggiemon is offline   Reply With Quote
Old 02-21-2009, 01:06 PM   #2
Profile:  Corona , California
Originally Posted by reggiemon View Post
Hi,
Thanks!
Tape and putty are temporary fixes.
Vulkem lasts for 40 years or more.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Window sealant Pepsi Windows & Screens 1 01-22-2009 01:16 PM
Drape bottom rails walter1 Upholstery, Blinds, Walls & Interior Finishes 20 11-07-2007 07:34 AM
Glass to window frame sealant crispyboy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 04-21-2007 10:33 AM
Window Sealant Sundance Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 04-21-2007 09:35 AM
Drip, Drip and Crack jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 09-06-2006 08:17 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
