Old 06-08-2009, 06:13 PM   #1
1994 30' Excella
Napanee , Ontario
window caulking??
Hello,
the curved dark plexiglass or plastic window covers over the front windows of our 94 Excella are out of the aluminum frame channel on the bottom of the frame. I worry about water getting into the channel in the winter and freezing. In order to repair this, should I take the whole curved plexiglass panel out or can I simply lay a bead of something over the outside surface---if so, what stuff? Advice would be appreciated.
Regards
Brian
Brian Hobin is offline   Reply With Quote
What Is All This Caulking? woodedareas Leaks - Weatherstrips, Gaskets, Caulks & Sealants 13 01-24-2007 05:33 PM
Caulking Warbs Argosy Motorhomes 0 10-20-2005 05:57 PM
Bathroom Caulking Excellaphant 1987 - 1989 Excella 2 10-25-2004 09:10 PM
Caulking Kistler Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-19-2003 12:32 PM
caulking ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 07-10-2002 02:13 AM
