Old 12-20-2009, 05:15 PM   #1
2013 23' FB Flying Cloud
Fort Jones , California
Question Why is my roof leaking around AC unit?
I recently purchased an '01 Bambi...brought it home, cleaned it up some, then with our first real rainstorm went out to check for leaks. I unfortunately found water dripping down thru the AC unit. I tarped over the AC unit and that stopped the leak....at least temporarily.
I removed the louvered plastic interior vent cover from the AC unit and felt up inside where the AC unit rests on the AS aluminum skin. There is foam rubber there...it was saturated until I dried it out.
Is there a gasket between the AC unit and the AS aluminum roof that needs replacement? Does the exterior of this joint (between roof and AC unit) get caulked; if so, with what? (I assume from other posts that the caulk to use would be Vulkem 636)
It is disconcerting to read all the numerous posts about leaks on AS roofs, but would like to start out right with my unit.....any help or advice you can give me about how to proceed to fix the leak around my AC unit would be appreciated........jack in NCal
jackwest is offline   Reply With Quote
Old 12-20-2009, 05:25 PM   #2
Replace the AC gasket, that's between the AC and the roof.
You will have to elevate, or move to the side, the AC to get the gasket in place.
Bath Roof Vent Leaking gaylejoe Roof Vents, Skylights & Fans 8 05-30-2008 06:32 PM
Leaking A/C roof gasket? ArtStream Furnaces, Heaters, Fireplaces & Air Conditioning 1 10-28-2006 11:30 AM
A/C unit on roof or indoor? Pschoerrn Furnaces, Heaters, Fireplaces & Air Conditioning 16 05-19-2005 08:49 AM
Best Price for roof A/C unit joossens Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-12-2004 04:50 PM
Safari roof still leaking Raptorrider2001 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 03-04-2003 11:32 AM
