White Roof Sealant on Newer Airstream
OK – Attempt three at posting this – I have localized my leak down to 3 to 5 rivets on my roof in the white painted area. First thought it was the AC – NOPE, then the stove vent – NOPE, window – NOPE, individually taped rivets and sealed the underside of the road side awning rail – no luck. Of course you have to stop and let stuff dry out so that you are sure where you are putting water is the real leak. After many days of trial and error – these rivets are the source! A couple of them are off center drilled holes with exposed penetration next to the rivet head.
OK – the question is – WHAT IS THE FACTORY WHITE SEALENT USED ON THE NEWER AS ROOFS? It’s all over the place up there. Tough stuff, rubber like, the installers must have been paid by the pound. I would like to get some tomorrow and do the sealant shuffle to get all the rivets covered.
Thank you for your help, Mike
Michael and Tina BZ 1966 17' CARAVEL 2003 22' INTERNATIONAL CCD WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
