Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 02-05-2007, 08:25 PM   #15
markdoane
Profile:  , Minnesota
Images: 59
I keep mine in the freezer with great results. Lasts at least 6 months after opened. I stick a deck screw in the end, wrap the nozzle with foil, and keep it in a freezer bag.
Non-contributing deadbeat.
Old 02-05-2007, 08:36 PM   #16
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
I normally use Vulkem, stick the screw in the end and wrap the whole thing in plastic wrap. I have left it in the freezer for over a year and it was still good...just wasn't sure about the Sikaflex. There are some caulks that are damaged by freezing.
Aaron
WBCCI #2449 AIR #2495
Old 02-05-2007, 09:03 PM   #17
markdoane
Images: 59
I don't thaw the Sikaflex before I use it. Using it cold causes surface condensation and helps it skin over.
Sikaflex 1a sealant Safari Tim Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 02-27-2004 05:37 PM
Installing roof AC. Need a sealant nds Clearcoat, Exterior Paint & Trim 8 07-22-2003 07:33 PM
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 11:00 PM
sealant Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 11-06-2002 09:41 AM
Vulkem sealant Stougard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-01-2002 01:25 PM
