Old 03-28-2013, 08:53 AM   #1
Stephenville , Texas
Which caulking should I use?
Ive been working on getting my '79 back up to par and while working on some of the exterior lights I have noticed some of the gray caulking on top of the windows and gutters has shrank, dried and can easily be scraped off with my fingernail. Im sure this topic has been beat to death but I want to double check against my examples.
On the pictures below I have highlighted in blue the areas in question that I want to start resealing. What do y'all recommend?
Also, what's best for sealing mounting holes and wire holes for clearance lights?
Gasgano1979 is offline   Reply With Quote
Old 03-28-2013, 10:20 AM   #2
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Trempro 635 (used to be Vulkem).
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 03-28-2013, 12:55 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Parbond for small seams, Trempro 635 for large seams. Get them both at Vintage Trailer Supply or Out Of Doors Mart.
Old 03-28-2013, 12:59 PM   #4
Ok, thank you for your input.
Also, since silicone is a no-no from what Ive read, what is the word on Lexel?
Lexel® - The superior alternative to silicone.
I use it quite a bit where I work and I think its great. Ive used it to seal shower stalls, cracks in brick, and seal A/C drip pans and have had great success. I was thinking about using it to seal around my vista view windows as they are a bit leaky and dont have the time or money to fix them quite yet.
Old 03-28-2013, 03:29 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
It's not polyurethane, so don't use it.
Old 03-28-2013, 03:50 PM   #6
eljay's Avatar
1968 24' Tradewind
I used a (shh...silicone) windshield sealant around my leaking vista views where the grey stuff had broken. I used this product to seal the glass into the frames as a temporary fix. I use Vulkem/Trempro for VV window frame to trailer seal.
My vista views are different than yours.
If you are using the Lexel for the glass to frame, maybe ok? I couldn't read/see if it contains acetic acid which would etch the aluminum for any other application.
Eljay
Old 03-28-2013, 04:07 PM   #7
1979 Argosy Minuet 7.3 Metre
Topping , Virginia
I've been using the Lexal and am satisfied. It's available at my local hardware store.
Paul
tarnished is offline   Reply With Quote
Old 03-28-2013, 04:29 PM   #8
Mrs.Mod's Avatar
1977 31' Sovereign
Fresno , California
We resealed our 77 Sovereign in January. We used a polyureathane sealant by 3M called 540. It comes in a few different colors. We've seen some trailer owners use clear sealant and considered it. After I scrapped all the old sealant off, I could see a little bit of etching in the aluminum from where someone had probably used silcone at one time. We ordered gray 540 and that helped to cover most of the etching.
You'll want to seal more than what you have highlighted in your picture. Reseal all seam laps, and all the way around all windows and anywhere water could find a way in.
My trailer is 31 feet long. I ordered 6 tubes of 540 and had one left over. Of course it depends on how generous you are with the sealant.
Cheers,
Cara, John & Johnny
Jet, Our silver stow-a-way
1977 31' Sovereign "The Mod Pod"
2006 Ford F-250 Super Duty
Mrs.Mod is offline   Reply With Quote
Old 03-28-2013, 06:14 PM   #9
eljay's Avatar
1968 24' Tradewind
Paul
On what areas please?
Eljay
Old 03-29-2013, 12:47 PM   #10
I think Leaks - Weatherstrips, Gaskets, Caulks & Sealants needs a sticky that has a definitive list of all of the different areas on Airstreams effected by leaks with lists for each area of appropriate sealants, gaskets, and fixes for each.
Just my .02¢
Old 03-29-2013, 01:20 PM   #11
cameront120's Avatar
1972 25' Tradewind
Just my .02¢
It's easier to make a list of areas not affected by leaks.
North Vancouver, BC
Old 03-29-2013, 01:51 PM   #12
At the very least the most common ones, sunlights, a/c seals, roof vents, areas above all the windows and doors, vista views and body line, ect. Im just learning all of this so I'm in the dark about a lot.
Perhaps an administrator can set up a voting thread so a list of areas can be compiled by those who have been effected by it. Once a list has been made, people can submit their fixes.
