Old 11-14-2006, 11:27 AM   #1
wannaroam's Avatar
1978 31' Excella 500
Harmony , Pennsylvania
Images: 36
where's the leak?
How do you figure out where your unit is leaking from? I have a leak at the front corner on both sides. Looking at this area I don't see any obvious source; no apparent seams loose or rivets. I realize that it can be coming from further away and running in the walls.
How do you figure this out? And after buying an older AS which has not been kept up well, what all should be done as far as sealing/re-sealing?
wannaroam is offline   Reply With Quote
Old 11-14-2006, 12:05 PM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
They can be tough to pinpoint, for sure, but some typical spots in the front are the marker lights and the windows. anything attached to or sticking out from the trailer up there could be leaking. (radio antenna? etc...).
I'd put a fresh bead of parbond on every seam in the endcaps, and the first main bow. also, the seams in the front lower panels, above the a-frame.
another common leak is at the "rub rail"...the molding that covers the joint between the banana wraps and the skins. If water gets behind that molding on some trailers, it gets dumped right onto the plywood floor. just go around the perimiter of the trailer, and gently push on the outer skins just above this molding. anywhere you can make a gap by pushing...seal it up w/ parbond.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-14-2006, 01:17 PM   #3
Daedalus's Avatar
1973 26' Argosy 26
Stone Ridge , New York
Roof Vents?
You should also look at roof vents as a potential source (especially for wind driven rain or when towing in the rain). The weatherstrip can become dry and then crack which will allow leakage. They should be checked/replaced as a part of your normal maintenance system (every 5 years or so?).
Good luck - look at it on the bright side, it's better than a leaky boat.
Daedalus is offline   Reply With Quote
Old 11-14-2006, 01:47 PM   #4
wannaroam's Avatar
Images: 36
On something like a roof vent should you try and get off any old caulking? And what would you use for it?
At least I know that it isn't the rub rail or the first set of rivets as we have the lower panel of the inside skin off and we can see it coming down the inside wall from higher up somewhere.
Old 11-14-2006, 07:29 PM   #5
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
The best way for us to find a leak was use a water hose, We had a leak around the curbside right corner when my husband ran the hose around the edge (bingo) we found it. As stated above the belt line.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 11-15-2006, 10:07 AM   #6
wannaroam's Avatar
Images: 36
Becky
Brilliant!
Leak somewhere in top section- B190 Van Luckydog Sprinter and B-van Forum 5 04-09-2010 05:09 PM
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Water leak James Schmidt 1993 Excella 1000 11 02-02-2004 07:54 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
