Old 09-26-2013, 11:12 AM   #15
Originally Posted by arktos55343 View Post
The window gaskets that I ordered from VTS are .375 wide and .25 high. The door gasket is .625 wide and .375 high. They work well, as long as they stay on. Would have ordered the extra adhesive, if I had known....
The correct window "D" gasket size is 1/2 inch wide and 3.8 inch high.
That also works on the entrance doors that used the double flared gasket which was used on the 64 to 73 trailers.
The 1974 and up entrance door gasket is triangular shaped and is 1/2 inch wide and 5/8 inch tall.
Old 09-26-2013, 02:30 PM   #16
1977 Argosy 24
Milltown , Wisconsin
Andy, I assume that you meant 3/8" high, not 3.8".
ventport is offline   Reply With Quote
Old 09-26-2013, 04:22 PM   #17
Ah yes, the . should be a /.
