06-08-2007, 08:09 PM
2009 27' FB Flying Cloud
Siloam Springs
, Arkansas
What will remove this stuff?
Some PO has applied the worst sealant ever over the entry door  . This stuff is clear like some silicon, but is nearly hard to the touch. It is very stuck to the skins, but not so well that it will stop any water. I have tried paint thinner, goo gone, and a heat gun. The latter makes it kinda gooey, but not enough to come off in any great fashion. Any Ideas?
Jeff & Cindy
Remi & Hunter
'09 27FB Flying Cloud
WBCCI #7026 Air #17054
"Fus-A-Lodge II"
06-08-2007, 08:37 PM
2005 28' International CCD
1977 Argosy 22
Western
, Oregon
Try brake cleaning fluid. Pour some on a rag and rub with the grain of the skin, then wipe clean afterwards removing excess brake cleaning fluid.This was a tip I learned from the AS tech at Airstream of Spokane for removing parbond that was left around the skin joint seals on my 2005 CCD.
I haven't tried it yet, so no guarantees on what you're dealing with. Good Luck!
Jim & Cheryl
2005 28' CCD
1977 22' Argosy
2004 Chevy Avalanche 2500, 8.1L 4.10 rear axle
Prodigy brake controller/Equalizer hitch
Honda 3000 genset
WBCCI #3538
06-08-2007, 08:40 PM
Well Preserved
Colfax
, North Carolina
Do you think he used hot glue? If he did, the only thing that will take it off is heat, and and scraping it off.
Intelligence is learning from your mistakes. Wisdom is learning from others' mistakes.
06-08-2007, 10:08 PM
1966 24' Tradewind
Placerville
Gasket remover worked very well for me on silicone. It can be found at auto supply stores
Neil and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
At home for
Spring
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
06-09-2007, 11:14 AM
2000 25' Safari
West of Fort Worth
If you're going to try brake fluid, just keep in mind that it is also an excellent paint remover. It will remove any clearcoat that you get it on.
06-09-2007, 03:24 PM
1966 24' Tradewind
Placerville
Gasket remover removes paint too.
Neil
FreshAir #12407
Avatar;
At home for
Spring
1966 Trade Wind
455 cid
455 cid
06-09-2007, 04:23 PM
More than one rivet loose
Missoula
, Montana
Acetone or MEK? Wear glove and a respirator if inside. Ventilation is a must.
These wil remove any celar coat or paint as well.
IF the heat gun makes it soft you can try a plastic scraper. THey can easily be ground into any shape desired. Buy more than one.. the break easily.
Michelle TAC MT-0
CP*2 blocks off US 12 and US 93
30A+10A/30A and Water
Sarah, Snowball
I'd rather send my money to Mexico it keeps them there!
06-09-2007, 05:06 PM
Well Preserved
Colfax
, North Carolina
You can also buy plastic razor blades that will fit into the holder for the metal single edge blades at most DIY-oriented auto parts stores.
06-09-2007, 07:21 PM
Siloam Springs
, Arkansas
Thanks for the input. I have had moderate success (before the post) with the heat gun/plastic putty knife. Was afraid to try any chemicals, the trailer has good clear coat. Y'all comfirmed my theories. Guess I will contiune with that, and hope my elbow remains intact. Terry, thanks for the plastic razor blade tip. I haven't seen those.
Jeff & Cindy
Remi & Hunter
"Fus-A-Lodge II"
06-09-2007, 08:14 PM
Well Preserved
Colfax
, North Carolina
You will find them in the Help! (motormite) section, in 5 packs.
| Thread Tools |
| Display Modes |
