Old 05-08-2011, 05:19 PM   #1
chrischarles's Avatar
1977 31' Sovereign
Florence , South Carolina
What type of caulking material to use?
The photo shows a caulking compound above the windows and entry door on our 1977 Airstream 31 foot International Sovereign. Want to replace the caulking and don't know what type of caulking material to use. Can someone point me in the right direction?
chrischarles is offline   Reply With Quote
Old 05-08-2011, 05:50 PM   #2
What you see is the original Vulkem sealer, which is still used. A creamy version of Vulkem is sikoflex.
Small seams are sealed with Par-bond.
Old 05-08-2011, 07:11 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
That Vulkem sealer has a lifetime; I've got a leak in my blackwater vent housing that I can't even see, but that's where the leak is.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-08-2011, 07:22 PM   #4
Mike.
Easy answer.
Take a sewer vent pipe cover off, and you should find a bad gasket. That gasket only lasts 2 to 3 years, or so.
Old 05-08-2011, 08:16 PM   #5
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Mike.
Easy answer.
Hey Mike I hear that desert air dries those gaskets out faster.
Cheers, Dan
Old 05-08-2011, 08:18 PM   #6
Mike Leary's Avatar
Images: 11
Mike.
Easy answer.
First thing I thought about, Andy. However, the PO (or AS) had sealed the outside with what I thought was Vulkem, maybe not. However, I sealed the cap (I thought maybe the boot around the abs vent was leaking) and ran water and the leak was on the outside between the roof and cover. I further went to find the leak by putting towels on the upper part of the vent cover, and, during a NW heavy rain, no leak. I'm going to try to re- seal it with my favorite Par-bond after drying the area off. Otherwise, I'll pull the vent housing and start over.
Old 05-08-2011, 08:37 PM   #7
Mike Leary's Avatar
Images: 11
Cheers, Dan
You're right, first thing I thought about was those seven months in the desert. I'd hoped everything would swell-up when we got back to the "green & grey". I'll tell you one thing: there is no mold or moisture in the rear "hidden" compartments under the beds as was usual when we stayed up north for the winter. The other plus (so far) is the desert air brought spiders into the coach that seemed to get rid of the ant population that have tormented us when we're north.
Old 05-09-2011, 08:39 AM   #8
Mike.
Take the cover off, and find the surprise.
The cover doesn't leak, the gasket inside of it is the culprit.
Old 05-09-2011, 08:51 AM   #9
Mike Leary's Avatar
Images: 11
Mike.
Before I pull them, do you have two in stock?
Old 05-09-2011, 11:04 AM   #10
Nope. But we do have 53 of them.
Old 05-09-2011, 11:55 AM   #11
Mike Leary's Avatar
Images: 11
Should I re-seal them with Vulkem or would Par Bond work as well or should I bother with new gaskets? Will order some up today, thanks, Andy.
Old 05-09-2011, 11:58 AM   #12
Seal them with Vulkem.
Old 05-15-2011, 10:04 AM   #13
Hueytownalss's Avatar
Hueytown , Alabama
Sealers
ANDY, I appreciate your many posts to the different threads. It always helps, to not only have help and advise from other AS owners, but also from someone in the "business".
I have several areas to "seal", i.e. seams, Ateood water heater install, lights, etc. Can you tell me the difference between butyl tapes, putty tape, vulkem.
Hueytownalss is offline   Reply With Quote
Old 05-15-2011, 10:29 AM   #14
Butyl tapes and putty tape, should never, EVER, be used on an Airstream, as they have a very limited life.
Big seams use Vulkem or Sikoflex.
Small seams use Parbond.
All of those last at least 40 or more years.
The key to a good sealing job, is to make sure that the area to be caulked is free from any chemical, and is absolutely clean.
Hatch hinge material TPdrums Exterior Storage Compartments & Access Doors 10 01-31-2014 07:42 AM
silicone caulking for round stainless steel sink toastie Sinks, Showers & Toilets 6 04-07-2011 06:28 PM
Replacement flooring material polarlyse Repairing/Replacing Floor &/or Frame 10 04-01-2011 04:07 PM
Exterior Aluminum type for an 1988 Excella? Rob&Julie Ribs, Skins & Rivets 0 02-14-2011 08:04 AM
Exterior gasket material? NicheVintage Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-31-2011 08:56 PM
