Old 11-08-2011, 10:17 AM   #29
Originally Posted by Chillpoints View Post
Thanks Andy
Would you suggest leaving this in place and simply adding a new layer to it? Can it be as simple as applying some Sikoflex over what is there?
Yes and yes.
Old 11-08-2011, 10:43 AM   #30
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
A heat gun and a plastic, wood or other non-scratching scraper is the best way to get the bulk of the old Vulkem caulk off - then its naptha or mineral spirits to dissolve the remainders & terry cloth abrasion if 100% of it needs to go!
Hatch hinge material TPdrums Exterior Storage Compartments & Access Doors 10 01-31-2014 07:42 AM
silicone caulking for round stainless steel sink toastie Sinks, Showers & Toilets 6 04-07-2011 06:28 PM
Replacement flooring material polarlyse Repairing/Replacing Floor &/or Frame 10 04-01-2011 04:07 PM
Exterior Aluminum type for an 1988 Excella? Rob&Julie Ribs, Skins & Rivets 0 02-14-2011 08:04 AM
Exterior gasket material? NicheVintage Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-31-2011 08:56 PM
