Old 03-26-2006, 07:52 PM   #1
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
What to use to keep window seals/rubber soft.
Hi guys.
Question, What product do you use/recommend, to keep the rubber around the windows and lights from getting hard?
R/
Safari-Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 03-26-2006, 09:28 PM   #2
_
hi rick
the factory uses a specific silicone spray....as i recall it's spelled oddly...like slip1cone....i have a can and will post a pic when i find it....
any silicone spray that is safe for rubber would work...for example napa has one that is used for treadmills, rubber seals and trim....while they've also got one that isn't to be used on rubber parts....
cheers
2air'
Old 03-27-2006, 05:25 AM   #3
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
303 Aerospace Protectant
We used 303 Aerospace Protectant which my husband bought at a spa/hot tub dealer. It can be used on rubber, winyl, fiberglass, tires, plastic and leather. 100% Prevention of UV caused problems. Instructions for rubber seals say to spray on and let sit for 5 min. then wipe dry. Seemed to do a great job for us and costs about $8.00 for a 8 oz. spray bottle.
enduroryda is offline   Reply With Quote
Old 03-27-2006, 06:10 AM   #4
403 Protectorant
I also agree with the post about using 303. It comes highly recommended by fabricators of rubber products as well as leather. It has the ability to reduce deterioration due to harmful sunlight wavelengths.
rtaylor537 is offline   Reply With Quote
Old 03-27-2006, 06:22 AM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Fantastic Vent also recommends 303 so that is what I started using on all rubber seals.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-27-2006, 06:24 AM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I use a 3M product called Silicone Lubricant Plus #08877. This product is developed for the rubber seals on the window tracks and around the windows. I believe it is also available at Vintage Trailer Supply http://www.vintagetrailersupply.com/
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
