Old 08-22-2011, 10:12 AM   #1
Trailer Trash Trez
aluminomad's Avatar
1968 22' Safari
Rustic Pond , Maine
What the sealant?
HEEEEEELP!
we have a leak & since we are living in our aluminum tent, need to fix FAST, but we are not sure what to use to get previous sealant off & what to use to re-seal? (SEE PIC) it's the area around the hatch where it attaches to the outer shell. We can't go somewhere to get it done, so must figure out how to get up there to fix (so any idea in that dept is also helpful)
forecast calls for 2dry days then rain again... UGH
life is Organic... life is Random... life is GO... so what are you waiting for?
http://www.aluminomad.org peace~ TREZ
aluminomad is offline   Reply With Quote
Old 08-22-2011, 10:31 AM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
What you need is "Vulkem 116." I'm not sure if you have a rubber gasket or not. That old stuff is a bearcat to remove; I've used a thin chisel and my Dremel grinder to remove the rest. Any solvent will work to clean the surface before applying the new sealer, carefull to avoid spilling any solvent. One more thing: BE CAREFULL on that ladder!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Sealant for Running Light Connector?? tinbender Lights - Interior & Exterior 4 07-18-2011 11:31 AM
Inside Sealant around Windows? J5MM General Interior Topics 3 05-13-2011 01:16 PM
Removing sealant around my vent pipes on a1989 345LE Motorhome. maxr Classic Motorhomes 0 03-22-2011 08:29 PM
Silicone tent seam sealant over rivet heads jayg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-10-2011 10:25 AM
How much sealant do I need? WadenMichell Leaks - Weatherstrips, Gaskets, Caulks & Sealants 13 02-05-2011 08:55 PM
