Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 08-08-2006, 07:46 PM   #1
yukionna
yukionna's Avatar
Profile:  Massachusetts
Images: 18
What kind of caulking to use
I'm starting to put our Bambi II back together again and will need to caulk two areas and would like recommendations on what product to use. The original caulking is still soft and is light gray in color.
The two places I need to caulk are:
1) Underneath the metal strip on the floor of the doorway into the trailer. The metal strip screws into the sub-floor through the linoleum tile.
2). Behind the outside metal used to secure the cover on the hot water heater.
WBCCI Region One
"Repression provides a temporary solution." ~ Paul Williams
yukionna is online now   Reply With Quote
Old 08-08-2006, 09:19 PM   #2
63air
Profile:  1963 19' Globetrotter
Moline , Illinois
I believe you need butyl rubber caulk, flat and about 1" wide. Should be available at any good RV dealer.
63air is offline   Reply With Quote
Old 08-09-2006, 07:38 AM   #3
yukionna
yukionna's Avatar
Images: 18
Can anyone recommend a brand name they have successfully used?
In researching caulk on the internet, I find it interesting that butyl rubber caulk is rated lowest amongst all caulks for home application. Perhaps that is because in the home, most homeowners aren't caulking metal to metal surfaces.
Here is a website I found that lists various butyl rubber caulks.
http://www.thomasnet.com/products/se...6103122-1.html
WBCCI Region One
Old 08-09-2006, 08:28 AM   #4
A-Merry-Can
Addicted to Aluminum
A-Merry-Can's Avatar
Profile:  1959 18' "Footer"
1962 19' Globetrotter
1964 24' Tradewind
Woodstock , Georgia
i used Vulkem when i reskinned our 18 footer. it's great stuff. i had to remove one panel, after it dried, it was d@mn near impossible to peel apart. that stuff STICKS. very water tight!
you can touch up seams with alcoa gutter seal. it wicks in very nicely. for a clean seam, put a piece of tape down the center of the panel, slice it on the seam with a knife, squeaze in the alcoa with your finger, and remove the tape. no leaks!
both available at vintage trailer supply.
good luck!
jp
8576 • • • • • • • •
there's always room for one more!
• • www.toolbox-design.com • •
A-Merry-Can is offline   Reply With Quote
Old 08-09-2006, 08:55 AM   #5
yukionna
yukionna's Avatar
Images: 18
Thanks for the input. Because of its "stickedness", I don't think Vulkem is a good choice for the hot water heater cover as I may need to remove the cover in the future for hot water heater maintenance purposes.
WBCCI Region One
Old 08-09-2006, 09:14 AM   #6
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
good call. i didn't realize it was a removable panel. that putty stuff would probably work great. it was all over my 18 footer when i took off the eyebrows, lights, etc, etc.
jp
Old 08-09-2006, 09:51 AM   #7
yukionna
yukionna's Avatar
Images: 18
Found it locally
Thanks for the lead on this. I found some at my local RV dealer:
It costs $3.86 for a 20-25' roll (1" wide). For anyone in New England going to Region One rally -- I want to extend an offer to pick up a roll for you (while supplies last). Let me know if interested as I plan on picking it up on Saturday this week.
WBCCI Region One
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 08:15 PM
Caulking Kistler Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-19-2003 01:32 PM
What kind of paint for a louver cover for a wall panel heater cindy General Interior Topics 1 09-19-2002 09:38 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 06:39 PM
caulking ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 07-10-2002 03:13 AM
