Old 05-25-2014, 11:53 AM   #1
1968 26' Overlander
Duluth , Minnesota
What is this sealant and how do I remove it?
I have been working up on the roof replacing missing and damaged vents. vent. PO put a lot of some mystery substance with embedded mesh tape around everything. I am having a difficult time figuring out what this stuff is and what solvent works with it. A heat gun has worked in some places where it is thicker, but the thin stuff is hard as a rock and does not want to budge! I tried some Gel stripper that didn't seem to dissolve it at all. Any body know what this stuff is and how to remove it?
Thanks!
ID:	212761   Click image for larger version
Bunkroom is offline   Reply With Quote
Old 05-25-2014, 12:04 PM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Is that just duct tape residue, or was there another sealant beneath? You might try Goo Gone and/or WD40.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 05-25-2014, 12:07 PM   #3
kokopat's Avatar
Hendersonville, NC , North Carolina
First one looks like screen wire used in the waste vent covers. Mine didn't go out that far or reach the roof. second one looks like the awning disintegrated while on the trailer. The third one looks just like mine did in 2008 when I bought it. I used a plastic paint scraper on the last one. Good Luck! Pat
kokopat is offline   Reply With Quote
Old 06-02-2014, 01:13 PM   #4
1968 26' Overlander
Duluth , Minnesota
It is not duct tape residue. The mesh is imbedded in a very hard sealant. Can't budge it. Where it is loose, it cracks off. Thank you for the thoughts.
Old 06-02-2014, 02:11 PM   #5
1988 25' Excella
Trumbull , Connecticut
Caulk Removal
Hi Bunkroom. Did you try heating the caulk with a hair dryer, being carefull not to get the area too hot?
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 06-02-2014, 03:03 PM   #6
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Try soaking a rag in mineral spirits and then laying it on top of a patch of the sealant for a while. This might loosen it up enough to scrape.
Old 06-02-2014, 03:56 PM   #7
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Lacquer thinner works on lots of stuff - better than paint thinner.
Silver Hawk is offline   Reply With Quote
Old 06-02-2014, 04:38 PM   #8
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Looks a little like the reinforcement mat for fiberglass and a resin coat which if it is then plastic scraper or 2 a little foul language and time! It will come off but it will take a couple of hours and some WD-40 to loosen the bond. The PO probably got frustrated and did not know about the forums so they improvised.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 06-03-2014, 01:13 PM   #9
1968 26' Overlander
Duluth , Minnesota
I had the pressure washer out today trying to flush out the deposits in the water heater. I saw the ladder there next to the O'lander so I climbed up and blasted away at some of that old sealant and it came right off! Nice. It took the old butyl tape right off the back of the fridge door, too! Thanks, all.
Front end cap sealant removal and polish Astro66 Cleaning, Stripping & Polishing 1 11-04-2010 07:10 PM
Roof sealant removal and a leaky fridge vent Rob&Julie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-02-2010 05:47 PM
74' Excella, to remove wiring or not to remove? BaltiHimal Electrical - Systems, Generators, Batteries & Solar 3 05-30-2010 10:23 AM
How to remove old sealant? FC7039 Cleaning, Stripping & Polishing 6 09-05-2007 11:14 AM
Shower and bath countertop wax sealant Hunchy Sinks, Showers & Toilets 15 07-15-2007 11:06 PM
